car stalls under hard braking
Old Jun 2, 2010 | 12:18 AM
jcopin's Avatar
Hey guys, my girlfriends 07 v6 vert is having a issue. It will stall when she brakes hard. i checked the spark plug wires and the vacuum lines and theyre ok. The car has 56k on it. could the battery or alternator be doing it? Would the torque converter be the more likely suspect?
any help would be wonderful.
thanks
Old Jun 2, 2010 | 01:13 AM
Stinger's Avatar
Is it low on fuel when it happens?
Old Jun 2, 2010 | 01:31 AM
DynamicmustangGT's Avatar
Manual or Auto? If manual is she leaving the gear in?
Old Jun 2, 2010 | 07:06 AM
jcopin's Avatar
it is a automatic and has happened with anywhere from a 1/4 tank to 1/2 to my knowledge
Old Jun 2, 2010 | 08:25 PM
colbymh's Avatar
First thought to check... Clean MAF and throttle body.
Old Jun 2, 2010 | 11:01 PM
jcopin's Avatar
actually that was the first thing i did
just replaced the original battery and belt tonight
seafoamed it last night
its still under its 5/60k powertrain warranty so its going to the dealer friday
Old Jun 8, 2010 | 02:05 PM
icemant180's Avatar
Sounds like a plug/timing issue. Would be interested to find out what the mechanic tells you
Old Jun 8, 2010 | 02:12 PM
In the 'old days' it would typically be vacuum related. When you say you checked the lines did you use a guage? Perhaps a tiny slit in a line is missed by the eye but enough so when under hard demand it leaks...
Old Jul 2, 2010 | 09:48 PM
amilia's Avatar
Many things can cause an engine to run hot, make sure that the cooling system is full, that there are no leaks, make sure the cooling fan is operating properly, make sure that the there is nothing blocking air circulation thru the radiator fins, check for corrosion inside the radiator causing blockage and reduced cooling.
Old Jul 4, 2010 | 08:03 AM
jglnaz's Avatar
In the past I had a few automatic cars do the same thing.
One occasion it was a faulty torque converter. It was not working properly and caused my car to stall when stopping.
Another time it was an almost plugged up fuel filter/fuel pump. This was a mechanical pump on the block, not the electric like the Mustang has in the gas tank. The car would accelerate fine, but at times under braking it would stall.
I agree with some of the other posters when I thought a vacuum leak could be a main culprit.
Any trouble codes displayed?
Good luck and I hope the issue is resolved soon.
Jim74656
May 1, 2023 02:15 AM
RRRoamer
Jan 19, 2017 05:27 PM
southern stang
Jul 29, 2015 08:41 PM
Michael Follett
Jul 24, 2015 06:58 AM
AMWill
Jul 20, 2015 08:40 AM
