Car is going to failsafe alot.
Old 1/11/06, 05:57 PM
Shifty's Avatar
My car keeps droping into failsafe mode. It isn't throwing any codes. The check money light isn't even coming on. I've got intake/exhaust, tune. I also got some new wheels/tires that were diff diameters. Would the wheels cause this? Would the tune? I'm guessing I've got a bad tune from my shop or something.
Old 1/11/06, 06:07 PM
RPM
RPM's Avatar
Throw the stock tune back on and see what happens.
Old 1/11/06, 06:22 PM
JeffreyDJ's Avatar
Best advice is right there. And on the first reply.
Old 1/11/06, 08:04 PM
wild stray's Avatar
Switch to the stock tune. If that fixes the problem, as far as failsafe, then get your car retuned right away.
Old 1/11/06, 08:55 PM
RPM
RPM's Avatar
You can run an aftermarket intake with a stock tune just as long as you don't drive it hard, under a heavy, sustained load. This depends on the intake of course, some don't require retune so that point is moot. C&L allows vehicle operation & stock tune with the caveat that you drive with a light foot. That is why I posted "try the stock tune". Make one change at a time.
Old 1/11/06, 09:09 PM
JeffreyDJ's Avatar
Originally posted by Blazing Saddles@January 11, 2006, 11:04 PM
I've seen cars with a CAI that wouldn't even start with a stock tune.
I've seen plenty more that will. Putting back to stock should be the first thing he tries. Don't you think an improperly tuned car would be worse then a stock tune with an Intake?
I guess technically he should pull the code first, but he should try that first. And/or get a new tune with less agressive timing to try.
Old 1/11/06, 09:10 PM
RPM
RPM's Avatar
I don't doubdt you. In this case then and to prevent further problems his best recourse is to discuss the problem with his vendor/tuner/intake mfgr.
Old 1/11/06, 09:18 PM
wild stray's Avatar
I know the C&L, MMR & my JLT will run with a stock tune on my car, because I've done it. You can pick up a inexpensive code checker at your local auto parts store. You can get a lot of good info from one over time.
Paul
Old 1/12/06, 06:11 PM
70MACH1OWNER's Avatar
Location: New Carlisle, Ohio (20 miles north of Dayton)
Paul
Mine ran about 10 mins. on the stock tune with the C&L intake. Threw 2 codes. Left bank lean- Right bank lean. I am sure every car is different.
Scott
Old 1/12/06, 06:15 PM
Shifty's Avatar
I forgot to say I already did the stock tune thing. Last sunday was when the real failsafe problems started. I couldn't even get 10 ft on my aftermarket tunes. Then I put it on the stock tune and it ran fine for a few days (keeping my foot out of it) but it went back to failsafe again. Still no codes, no CEL. Maybe it's going to failsafe on the stock tune beacause of a lean condition? I know there's a code for that though.
Old 1/12/06, 06:42 PM
wild stray's Avatar
Scott
Mine thew codes with the JLT also, but I was able to drive it temporarly til I got to my tuner.
Old 1/12/06, 06:44 PM
wild stray's Avatar
When I had the C&L on my car it went into failsafe one night. I checked the intake tube and it was loose. I tightened it up, shut the car off and restarted it. No CEL and no failsafe.
Paul
Old 1/12/06, 09:12 PM
thestoogeo's Avatar
Call me crazy, but I drove my ProCharger with 39lb injectors to the gas station on a stock tune. I would say try the stock tune also.
Jon
Old 1/12/06, 09:27 PM
Shifty's Avatar
Paul
That's an idea. I'll try that and I'll clean my filter.
Old 1/13/06, 06:33 AM
SC67Stang's Avatar
Put back your stock airbox and stock tune and start from there.
I don't think I have heard about exhaust causing this, so this should be safe.
Go back to your tuner and run the car on the dyno with the tune and CAI to see what is actually going on.
Just my 2 cents.
Old 1/13/06, 09:45 AM
Route 66's Avatar
Start from scratch. Drive it backwards back to the dealership. Then park it with the other Mustangs. Get out, walk around it, kick the tires. Get back in and drive it off the lot. Should be ok after that.
Old 1/15/06, 03:17 PM
Shifty's Avatar
Ok I cleaned everything and drove it again. Went to failsafe but this time it turned on the CEL light and threw a code. P2106, a TPS sensor code. I think this has to do with TSB 05-14-4. I called up some dealers and they don't seem to have a clue what I'm talking about related to this TSB. The part number doesn't even exist for them! WTF is going on?
Old 1/15/06, 03:22 PM
05-1947's Avatar
where did you get your tuner from, and have you contacted your supplier about it?
Quick Reply: Car is going to failsafe alot.
