In-car camera mounting options?
Try B&H Photo (www.bhphotovideo.com)
Here are a few results:
http://www.bhphotovideo.com/c/produc...CUP_MOUNT.html
http://www.bhphotovideo.com/c/produc...r_Suction.html
(this one is quite expensive but you can even mount a camera on the side of the car at highway speeds)
http://www.bhphotovideo.com/c/produc...up_Mount_.html
http://www.bhphotovideo.com/c/produc..._Cup_with.html
Hope these help
Hope these help
Someone on here has one of these if I remember correctly. TacoBill maybe?
http://www.stickypod.com
I saw a guy at my last HPDE that was running a Ford Focus, he had an in-car camera set up using a metal bar, drilled in two places so that the headrest supports could pass through it--this way it could be mounted between the headrest and the seat body.
The bar was long enough to extend out into the area between the passenger seats, and had a stud w/ a bolt to hold it on that was used to attach the camera.
If you've got access to basic metalworking tools, you can make one of these for cheap!
http://www.cruisecam.com
Bought one of these for my Father. I made one for myself from aluminum and by the time I was done it cost about $5 less then one from Cruisecam.
The cruisecam unit is well built and adapts to every car without doing any damage to the interior.
(in car video using cruisecam at www.beauchampengineering.net - my personal site)
for my last in car video, I just used my tripod and bungee cords. I put one leg on each side of the floor (passenger and driver), so it was straddling the hump. The third leg was on the hump on the back seat. I bungeed the third leg using the lower inner car seat mounts. My bungee cord hooks fit perfectly into the hold and around the car seat mount. I bungeed both the other legs to the seat rails. It turned out to be very sturdy, and all I spent was $5 on bungee cords, since I had the tripod already. Except for my wheel hop, it didn't move. I didn't even have it strapped down as tight as I could have.
http://www.youtube.com/watch?v=N5sabliM3YU
Can be used for in-car or outside.
x2 on the CruiseCam bar. I used it during my last track session and it worked perfectly and is very solid. I got mine from http://www.soloperformance.com
9/16/15 06:44 PM
