Brake pedal response
Old Oct 29, 2007 | 12:56 PM
I-70 west's Avatar
I`m tired of spongy brake pedal !
What has anybody done to improve ?
Braided front brake lines, will this do it ?
Old Oct 29, 2007 | 01:02 PM
MustangRetribution's Avatar
i dont have this problem, i thought these brakes were more responsive then my 02 stang
Old Oct 29, 2007 | 01:33 PM
Little Black Pony's Avatar
Yep, braided lines should work to stiffen the pedal. I'll be putting 'em on my Pony after winter.
Old Oct 29, 2007 | 01:37 PM
StillenMustang07's Avatar
Authorized Advertiser
Hey there,
Braided brake lines will help a great deal. Look at spending around $200 for a good set.
Page
Old Oct 29, 2007 | 04:16 PM
bad_monkeys's Avatar
I did the lines and they really do not help much. The only way around it is with a brake kit.
Old Oct 29, 2007 | 07:44 PM
boduke0220's Avatar
bleeD the brakes, you might have air in the system!
* if this is an ignorant remark please ignore it*
EDIT:type-o
Old Oct 29, 2007 | 11:55 PM
theedge67's Avatar
Spongy brake pedal probably means air in the lines somehow. Either it
1) came that way from the factory for some reason,
2) you got air in the lines when you messed with them some time,
3) you boiled some fluid doing some major braking action.
Old Oct 30, 2007 | 01:24 AM
I-70 west's Avatar
I did bleed them a few months back and did see some air bubbles which gave me some improvement but it still needs major improvement compared to some other cars I`ve driven lately. I was told that a vacum bleed is the only way to properly do them and I did the old fashion way, me on the wrench and somebody on the pedal. Maybe I should go to my dealer and get them to check it as a warranty item.
I was hoping somebody had the scoop on this already
Old Oct 30, 2007 | 10:51 AM
theedge67's Avatar
Different lines won't help if you have air in them.
Try bleeding according to the service manual:
http://bradbarnett.net/service_man/C...m_Bleeding.pdf
Old Oct 30, 2007 | 07:06 PM
RadBOSS's Avatar
Trust you bleed them in the correct sequence?
Old Oct 31, 2007 | 01:06 AM
I-70 west's Avatar
Yes, longest first to shortest
Gill5oh
Oct 6, 2017 10:50 PM
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
