Best Manual for dash removal
Old Jul 16, 2013 | 09:40 PM
tkfernau's Avatar
So I just bought a 2007 mustang GT and I am cleaning up a bunch of little things to bring the car up to spec. I am going to have to replace the mode door actuator and I can see that the dash will need to come out. The local shop I trust wants 350 in labor and I think I can do it. If anybody has a good recommendation on what manual is the best or they like I will stat there. Thanks for any help!
Old Jul 17, 2013 | 09:55 PM
houtex's Avatar
Here ya go:
http://iihs.net/fsm/?dir=461
Start with the console, then the center instrument stuff, then the entire dash after that. This is the 'bulk get it out' version, where you don't even take out the airbag or remove the dash trim pieces or ducts. Just yank out the entire dash complete. You *will* want a person to help ya with that, perhaps two...
Have fun! *said with a knowing groan...*
Old Jul 17, 2013 | 11:02 PM
Lime GT's Avatar
The manual doesn't show any dash removal for mode actuators but they are not easy to get to. A few pieces of duct need to be removed to access the left side actuator. If the actuator doors are broken the dash more than likely needs removal.
Old Jul 17, 2013 | 11:50 PM
jim010's Avatar
Ah, the fun of removing the dash ... did it 3 times.
Be sure to remove the rear view mirror as well. Definitely a 2 person job.
Old Jul 18, 2013 | 08:23 PM
houtex's Avatar
Yep, you're right. By the way, OP, that's here:
http://iihs.net/fsm/?dir=336
In case that'll help. And no, none of that's gonna be easy, since the car is literally built around the Heater/Evap core assembly.
Old Jul 20, 2013 | 10:20 AM
Lime GT's Avatar
I know on my 05, I had at least 2 maybe all 3 actuators out when I was trying to troubleshoot why I had little air flow to the floor while in Floor Mode and most out the defroster ducts. Ford wouldn't cover warranty claiming it worked as designed. I bought a used Climate Control Module from a wrecked 07 Shelby and I finally had control where I wanted the airflow distributed. After doing some research I found Ford did some HVAC redesign in mid year 06 production, particularly the upper defrost duct/demister area and other areas. There was a fair amount of documentation, including tsb's and special service bulletins, on this site with this issue, until the site crashed.
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
BigHoss
Sep 21, 2015 10:03 AM
jim010
Sep 14, 2015 10:15 PM
