Automatic bounces of rev limmiter?
Old Jan 28, 2006 | 03:02 AM
nynvolt's Avatar
Not sure what to make of this, my car is stock (only rims and exhaust) cruise control was set at 80, I punch it, the trans drops two gears bounces off the rev limiter. I thought it was a fluke but happened again a little later, same scenario. I never bounced off the rev limiter when shifting my own gears in a manual and never expected an auto to do this. Yes it was in "D", I don't try to shift my auto like a manualmatic or anything, just push the go pedal.
This isn't normal is it? Haven't had much experiance with automatics, so forgive my ignorance.
Old Jan 28, 2006 | 10:01 AM
ford4v429's Avatar
legacy Tms Member
I got a stick, but would sure think it wouldnt downshift 2 gears at that speed...suggest getting someone with a tuner to adjust shift points...if you got different tires, you might want to calibrate speedo at same time...
Old Jan 28, 2006 | 10:02 AM
korinwoodo's Avatar
You might wanna get off the cruise control first?
Old Jan 29, 2006 | 08:54 AM
nynvolt's Avatar
Tires are exact same overall diameter as stock, no calibration should be needed.
So cruise control allows the motor to rev beyond redline, hitting the limmiter? How odd.
Old Jan 29, 2006 | 09:04 AM
GOFISCH's Avatar
It should have shifted. Yes, the Autos when in 5th gear drop down two gears when stomped to the floor, 5th gear is Overdrive. I wonder if Cruise does have something to do with it. I'm going to check it out next time I have my car out.
jim010
Jun 24, 2024 04:23 PM
Detroit Steel
May 19, 2016 12:13 PM
yabutt
Oct 23, 2015 01:05 PM
bones302
Oct 7, 2015 04:42 AM
Fernando.4ohh
Sep 10, 2015 03:35 PM
