Anybody Else Have This Similar Problem?
Old May 2, 2013 | 03:34 AM
Chris728's Avatar
Hello everybody just wanted to see if anybody was or has before experienced this problem and could help me. I have the sequential turn signal harnesses installed in my 2007 Mustang GT from webelectrics and I just noticed today that 2 out of the 3 lights on the right signal will not light up. The brake lights work on all six lights but when turning on the right signal the two outer lights do not work. I know it is not the bulbs because the filament is still intact in both bulbs and it does not have a fast response that tells you when a bulb is out. I have a feeling it is the harness but not completely sure. Any ideas would be appreciated. Thanks in advance!
Old May 2, 2013 | 07:12 AM
Paris MkVI's Avatar
I believe these lamps are dual filaments - you may simply need to replace the lamps. I also have the WebElectrics - all I have had to do is replace lamps.
Old May 2, 2013 | 10:16 AM
mustangman1960's Avatar
WebElectric is pretty good at responding. Here is their email address.
techsupport@webelectricproducts.com
Old May 2, 2013 | 03:06 PM
stupidgenius36's Avatar
Just Plain Rude!
The first thing I'd check is the bulbs. They're cheap or you can even just swap them from the other side, and see if the problem still exists. If that doesn't fix it, then I'd shoot them an email.
Old May 2, 2013 | 10:48 PM
Scrape's Avatar
Sounds like bulbs to me. It's happened to me...sigh
Old May 3, 2013 | 07:34 PM
houtex's Avatar
Has anyone mentioned the bu... oh. Ok.
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Airborne42
Sep 24, 2015 11:01 AM
DrisStang
Sep 14, 2015 06:20 PM
