Another clunk thread.....
Old Mar 4, 2010 | 01:13 PM
SONICBOOST's Avatar
Arrow Another clunk thread.....
When I turn right I get an annoying clunk from the passenger front side.. Im guessing it has something to do with the suspension. I have the Eibach lowering springs with Steeda shocks and struts.. Any guesses or suggestions?
Old Mar 4, 2010 | 02:40 PM
97svtgoin05gt's Avatar
There was a TSB back when the '05s originally came out and I believe it was front suspension. You've changed a lot of your stuff so I'm not sure if it still applies to you or not.
Old Mar 4, 2010 | 03:02 PM
Cavero's Avatar
Could be upper strut mounts. I've heard of the stock ones (made of plastic) making a clunking or popping noise over bumps with aftermarket springs. Steeda has some metal ones but they're not that cheap.
Another possibility is the swaybar end links are loosening up. I had that problem about a year ago or so. It would clunk when turning or hitting a big bump with one side of the car. Regardless, I would make sure everything is still torqued to spec.
Old Mar 4, 2010 | 04:35 PM
SONICBOOST's Avatar
I was thinking someting might have come loose^^ I'm going to take it to the shop very soon.
Old Mar 4, 2010 | 05:08 PM
Cavero's Avatar
You don't have a torque wrench? It's very easy to do yourself
JMU
Sep 27, 2015 07:53 AM
00StangVert
1994-2004 V-6
Sep 11, 2015 12:08 PM
dream2015
Aug 31, 2015 03:55 PM
Mackitude
Aug 17, 2015 04:14 PM
John H
Aug 8, 2015 04:58 PM
