Aluminum Corrosion
Old Dec 10, 2004 | 12:27 AM
davids2toys's Avatar
Does anyone know about installing a 1inchx1inch piece of anode in the radiator so the anode will get all the corrosion and not your aluminum parts, i just read this in the last HOTROD magazine i read, it was a little column towards the back in the tips section
Old Dec 10, 2004 | 06:09 PM
Greywolf's Avatar
I thought aluminum didn't corrode isn't the anode for copper radiators
Old Dec 10, 2004 | 10:17 PM
Aluminum is very prone to corrosion, magnesium is even worse.
The tip i was refering to is on page 118 of Jan Hot Rod magazine, it was called "prestone witerizing tips", protect your heads, intakes and anything else aluminum.
I build and instruct on building Helicopters, aluminum corrosion is a very big deal...all you need is 2 different metals and water exposure and you are on you way to destruction
Old Dec 10, 2004 | 10:31 PM
wild stray's Avatar
Sounds logical....something similar to installing zinc plates on the underwater running gear of a boat, to attract electrolysis. The plates deteriorate instead of the running gear. Same principle as a anode installed in a hot water heater.
Old Dec 10, 2004 | 10:33 PM
wild stray's Avatar
Something to look into!
Old Dec 10, 2004 | 10:45 PM
38special's Avatar
I plan on rattling mine apart before it corrodes!
Old Dec 10, 2004 | 10:48 PM
mr-mstng's Avatar
Dave, could you scan the article? I'm interested to know ore about this. I figured the corrosion was simply aluminum oxidation, caused by exposure to water and air.
Old Dec 10, 2004 | 10:55 PM
wild stray's Avatar
If all the right elements are present, electrolysis will take it's toll rather quickly.
Anyway, something to look into.
Old Dec 11, 2004 | 02:25 AM
Wombert's Avatar
Wait a minute. I always thought aluminum DOES corrode, but the aluminum oxide is even harder than the aluminum itself and also very durable, so the aluminum oxide layer actually protects the aluminum?
Old Dec 11, 2004 | 06:13 AM
porsche's Avatar
who cares.
Old Dec 11, 2004 | 09:49 AM
here is the tip in HR mag, hopefully it works, last time i tried to scan and post it would not let me upload thatr type of file, maybe i'm doing something wrong...Oh well still wont work, it is telling me i cant uplkoad that type of file, it is a jpg?????
Old Dec 11, 2004 | 09:54 AM
The oxide does protect it to a point, that is the theory to anodizing, or alodine treating or plating, it is just a protective measure, same with different primers and paint, take away a component to stop the corrosion, the oxide will slow it down...put an aluminum part in the ocean for a week, you would shocked, it will delaminate and actually be falling apart
Old Dec 11, 2004 | 09:56 AM
Rob, what am i doing wrong with this attaching something to a reply
Old Jan 2, 2007 | 05:33 PM
Well I finally found the product, but it is not by prestone, it is being marketed by flex o lite...I just ordered it thru summit for 10.99, I bought a few of them, now I need to figure out where to install it in the cooling system...it comes with 1/4 " npt fitting and it is about 2" long. It is also on pg 121 of Oct 2006 Hot Rod mag.
Has anybody tried this yet???
Old Jan 2, 2007 | 06:10 PM
YardSpecial's Avatar
Originally Posted by porsche
who cares.
After 6 heater cores, this is a sign of relief for some people.
Heater cores are aluminum.................
Old Jan 2, 2007 | 09:43 PM
hi5.0's Avatar
I thought anti-freeze has corrosion inhibitors as part of the mix? Figured flushing/changing coolant on a regular basis would be enough.
Old Jan 3, 2007 | 03:02 AM
metroplex's Avatar
Frequent changes are supposed to cause heater core failures due to trapped air accelerating the electrolysis process.
Aluminum oxidizes but the oxidized layer is also pretty strong. Aluminum always oxidizes unless you have a sealant layer (like clearcoated paint).
May 3, 2026 05:42 AM
dblhelx
Oct 6, 2015 08:08 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
Sep 10, 2015 12:44 PM
