Alternator Power Ratings
Old Nov 29, 2004 | 04:24 PM
SurfnSoCal's Avatar
Does anyone know what the Power ratings are on the 05's alternator? How much it puts out...
thanks!!
Old Nov 29, 2004 | 05:31 PM
Mongoose's Avatar
thanks!!
Why do you think you need to know this?
Old Nov 30, 2004 | 12:36 PM
SurfnSoCal's Avatar
To see if my audio system I am thinking of will draw too much power from the alternator. I don't want to screw up the electrical system. Did that in my 2000 v6.
Old Nov 30, 2004 | 12:46 PM
Grantsdale's Avatar
The shaker 1000 has two subs and two amps in the trunk. Its also a bigger battery than 00, so I doubt it would be a problem.
Old Nov 30, 2004 | 12:59 PM
SurfnSoCal's Avatar
ok, you guys are doubting me I see. Here is the system I have waiting to be installed, pending delivery of my car-
Alpine CDA 9835
MB Quart PWE-130 5.25" components 130w
MB Quart PCE-213 5.25" speakers 100w
Alpine MRV-F540 4 channel Amp 150wx4
JL 8w0 8" midbass speakers 75w
Alpine MRP-T220 2 channel Amp 90wx2
JL 10w6v2 Subwoofer 700w
Alpine MRD-M1001 Sub amp 1000wx1
With a 4 chann, mono, and 2 chann amps all running. Plus neons under the dash...I am going to be drawing quite a bit.
Does anyone know the answer to my orginal question?
EDIT: Grantsdale, I see the confusion now. My bad. The system I have in my 2000 right now is nowhere close (power wise) to what is going in the 05.
Old Nov 30, 2004 | 01:24 PM
Mongoose's Avatar
That sounds like a good plan to me. Do you plan to run two batterys too?
Old Nov 30, 2004 | 01:44 PM
SurfnSoCal's Avatar
Originally posted by Mongoose+November 30, 2004, 12:27 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Mongoose @ November 30, 2004, 12:27 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-SurfnSoCal@November 30, 2004, 1:39 PM
That sounds like a good plan to me. Do you plan to run two batterys too? [/b][/quote]
hopefully not.
(were you being sarcastic? :scratch: )
Old Nov 30, 2004 | 04:48 PM
Chaotic Bliss's Avatar
I would like to know this too. No ones knows how many amps the alternator puts out?
Old Nov 30, 2004 | 05:12 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
I'll try and dig up any info I can on that. Something you guys with systems will also want to maybe include is at least 1fard capacitor. That will help balance any loads being drained by the system and help keep the headlights from dimming under heavy sound useage.
Old Nov 30, 2004 | 05:44 PM
SurfnSoCal's Avatar
oh yeah, 1f cap is definitly going in. anyone know how many amps it puts out?
Old Dec 1, 2004 | 02:42 PM
It sometimes says the output right on the alternator itself if someone with the car wants to take a quick peak.
Old Dec 1, 2004 | 03:04 PM
Red Baron's Avatar
I've read that both the V6 and GT models have 130 amp alternators.
Old Dec 2, 2004 | 10:59 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Here is what I have found out, i'm not 100% sure its accurate, but its all I got so far:
It's a bit of a tricky question...
The new Stangs are equipped with a "Smart Charge" system, so the alternator only puts out as much as is needed based on demand. This is all controlled by the computer.
I'm not sure what the peak output is, but I'm guessing somewhere around 130 amps. I'll look into it and post back.
<EDIT> It is 135 amps @6000 rpm (that's alternator rpm).
Old Dec 2, 2004 | 11:05 AM
BillP's Avatar
Does ANYONE even try to use Fords web site? LOL.
Go the the MUSTANG home page and then go to the SPECS page.
http://www.fordvehicles.com/cars/mus...eatures/specs/
See the "Manufacturer's Specs (PDF)" link? TRY IT!
For the instruction impaired-> http://www.fordvehicles.com/assets/p...tang_specs.pdf
The GT alternator has a 92 amp idle rating, 135 amp peak rating.
Old Dec 2, 2004 | 11:10 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
now that woulda been smart huh?
Old Dec 2, 2004 | 11:16 AM
BillP's Avatar
Old Dec 2, 2004 | 11:36 AM
SurfnSoCal's Avatar
oh......well......ANYONE could have done that. I wanted to see if anyone knew off the top of their head...
Old Dec 2, 2004 | 12:02 PM
BillP's Avatar
So it was a test, eh?
Old Dec 2, 2004 | 12:18 PM
SurfnSoCal's Avatar
um.....yeah....
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
