Airbag light: Code 22?
Old Mar 16, 2012 | 06:27 PM
cmplxlgc's Avatar
Over the last three days, noticed that my airbag light has been flashing then going to a steady glow after about a minute. I've noticed that it blinks twice, pauses and then blinks twice more. I've read on other sites that this is likely a code but haven't found much more about it. I've wondered if this is maybe a fuse problem or something in the steering column. Has anyone else heard of these "Morse code" style blinks from the airbag light?
Thanks in advance.
Old Mar 17, 2012 | 11:02 PM
cmplxlgc's Avatar
Ok, so after a little detective work on the Internet, it turns out "blink code" 22 refers to a short in the wiring to the driver's side seat airbag. The 8-way power seating is crunching the wires that lead up to the airbag self.
Apparently, this is a factory defect in the routing of the wiring under the seat which creates pinch points and there's a TSB out for it. I would suggest anyone who had a build date in early '07 read up in it. This resulted in the wires being severed in my case.
http://www.stangpit.com/wp-content/i...b/07-10-03.pdf
Attached Thumbnails Airbag light: Code 22?-image-3319124991.jpg
Old Mar 19, 2012 | 11:38 AM
FordService's Avatar
Hi cmplxlgc,
My name is Deysha with Ford Service. I recommend you have your vehicle diagnosed at your Ford dealer. Your Service Manager is in the best position to look into this for you. He can check into any warranty, Recalls, or Customer Satisfaction Programs that may apply to your vehicle. If you have any questions, do not hesitate to PM me.
Deysha
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
