Aftermarket springs and shocks
Old Jun 23, 2004 | 11:05 AM
acadian's Avatar
With all the talk about the Mustang ride height, I thought I'd start this new topic. Even if the pics we have seen of the mule are wrong, and the production cars will ride lower, I'm still thinking about lowering the car another inch or two with some Eibach springs after I put on some wider 18's. And possibly put some new shocks on there too. Does anyone have any experience at installing aftermarket springs and/or shocks on a Mustang? Is it fairly easy? Got any tips?
Old Jun 23, 2004 | 01:40 PM
bullittman's Avatar
I've done it a couple times on SN-95 's. You will need a spring compressor, also the car will need an alignment .
Old Jun 23, 2004 | 02:45 PM
ecgirard2's Avatar
How much should a spring compressor run and can you recommend a brand?
Old Jun 23, 2004 | 03:01 PM
dustindu4's Avatar
9 is not my lucky number.
some parts stores will let you rent them
Old Jun 23, 2004 | 04:09 PM
1 COBRA's Avatar
I did it on my '02 GT with a Razzi front air dam, which wasn't as low as the spoiler offered by Steeda and regret it. The bottom got scraped a few times coming out of steep driveways and going over parking lot concrete stoppers. The cornering improved and so did the car's stance, no doubt, but the ride quality suffered.
Old Jun 23, 2004 | 04:23 PM
bullittman's Avatar
I honestly can't recall the price or brand........Got from NAPA, but you can rent too.
Old Jun 23, 2004 | 04:28 PM
Galaxie's Avatar
I Have Admin Envy
I am pretty sure you can get away from using a spring compressor on the fox-bodies. This is because the strut and spring are not packaged together. You can wrap a chain and SLOWLY drop the control arm.
The '05 has the spring + strut together and will definitely need a spring compressor to unload the spring to remove the strut and hardware.
Old Jun 23, 2004 | 07:15 PM
Harley's gt's Avatar
you do not need a spring compressor on sn95's i did 3 cars without compressors
Old Jun 23, 2004 | 08:25 PM
hdwrench's Avatar
i'm sure the next question is "how?" although personally i am not that interested.
Old Jun 24, 2004 | 05:54 AM
MTAS's Avatar
Originally posted by hdwrench+June 23, 2004, 10:28 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (hdwrench @ June 23, 2004, 10:28 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Harley's gt@June 23, 2004, 7:18 PM
i'm sure the next question is "how?" although personally i am not that interested. [/b][/quote]
You use a floor jack to support the spring from underneath, then slowly lower the jack and the spring will come out by the time the jack is fully lowered. I've done it to 4 different SN95's with no injuries
Old Jun 24, 2004 | 06:53 AM
HairyCanary's Avatar
And make sure the spring is chained. It has only been about a year since someone was killed doing front springs on an SN95 because he didn't chain the springs. Sure, it hardly ever happens, but tell that to the 18 year old kid now...
Why are we talking about doing the springs in an SN95 anyway? Isn't this the 2005 forum? And it's got a 100% different spring setup.
Dave
Old Jun 24, 2004 | 11:43 AM
Shea's Avatar
Just out of curiosity, why would you spend the money to get shortened springs instead of just cutting the present ones?
Old Jun 24, 2004 | 01:03 PM
crazyhorse's Avatar
different spring rates (stiffness) to compensate for the shorter travel or to tighten the suspension up.
Old Jun 24, 2004 | 05:31 PM
tangs3's Avatar
Eibach and BBK make good springs, get the progressive rate springs good ride quality, have owned both ride good and handling is great.
Old Jun 24, 2004 | 05:41 PM
tangs3's Avatar
Not the safest way to modify your car if you cut them with a torch the heat can have an adverse effect on the springs causing failure, although people cut them all the time I dont recommend it. Springs are not really that expensive, and I believe you would be alot happier in the long run with the ride quality verses cutting your stock springs.
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
CoyotePremium13
Oct 7, 2015 07:17 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
