2008 Owner Pulled a Spark Plug?
I've read that they changed the head design and plugs to prevent the spark plug problems.
Some places were saying late 07 and others were saying Oct 07 which would be after some of the 08s were produced.
The new plug uses a fully threaded surface. HJFS 24FP appears to be the new plug part number.
If you're an 08 owner and looked at your plug, what does it look like? When was your car built?
This was posted on modularfords and is supposed to be the different plugs.
A couple of 07's have been pulled and have the new style, so I know at least a few have revised designs. I don't know anything other than friend reports and what others have been showing on the forums.
Noob question: I can't tell from these pictures Does the new design resolve the spark-plug-breaking-upon-removal-issue?
Now I need to pull mine to verify, I too have an early production 08. puchase date 8/19/09 Vin# 7093
Cool, let me know what version it is. I purchased my '08 on 8/25/07, so I probably have whatever you have.
Under the part number list it has spark plugs but it says see your authorized dealer. It also says that using plugs other than Motorcraft or equivalent may void warranty coverage. So basicly it says we can just stuff some tree limbs in there and see what happens.
If the picture in the OP is accurate, then it looks like there has been not only a change in the plug design, but also a change in the plug hole in the heads. The threads, besides running further down towards the tip. look smaller in diameter and start lower on the plug.
pulled 08 plug today
OK. Finally had time to pull a plug off my 08. Unfortunately, It's the same Motorcraft 2 piece design part # PZT1F.
So at least for me, no "'New " plug design or head change
.On the plus side the plug came out very easily, no lube and undone with fingers after cracking it loose
( no strange noises either)FYI-This is with 12K on odometer
Maybe someone with a newer unit than mine can check? Last 4 vin# 7093
