2007 V6 Convertible Pony Package Heater - help needed
Old Feb 3, 2015 | 09:40 AM
PONYEXP's Avatar
My 2007 convertible has a heat problem up here in cold Ottawa, Canada lately. The heater blows cold air which seems to warm a bit while driving, but turns back to stone cold at idle. On the other hand, I just discovered that if I switch on the A/C on any setting with the temp on warm, it warms up nicely and gets downright hot in the car after a few minutes of warm-up. Coolant level is fine, there are no leaks and airflow inside the car is good. Any ideas on what the problem might be? Thx
Old Feb 3, 2015 | 12:29 PM
Fear's Avatar
did you recently have it recharged? or maybe did some recent wiring?
Shot in the dark but maybe you(or someone else) switched some wires by accident since its working the opposite of how it should rather than not at all..
Old Feb 3, 2015 | 01:27 PM
PONYEXP's Avatar
My mechanic recently installed a new battery and starter! No new wiring that I know of.
Old Feb 3, 2015 | 01:56 PM
watchdevil's Avatar
Keep in mind the HVAC controls are electronic with microprocessors and switches even though it looks like a "manual" 3 **** system. It sounds like a failure of the switch assembly to pass current to the blend door actuator motor when the heat position is selected. If you are getting heat with the AC on then selecting a hot temperature then this has to be the case. That proves the actual blend door motor is functioning. The blend door motor regulates a flap that directs airflow from either the heater core or the AC evaporator.
This may be as simple as replacing the entire switch control assembly on the dashboard. Check first though to be sure all the plugs are seated properly into the back of the original unit.
You can usually get a good used switch assembly on eBay or from used salved parts.
Buffet Slayer
Tungsten Grey
Jul 29, 2017 01:32 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
CoyotePremium13
Aug 18, 2015 07:28 AM
ustabawannab
Aug 5, 2015 08:32 PM
DrisStang
Jul 24, 2015 07:58 AM
