2007 Mustang GT climate control issues??? HELP!!!!
ok so recently I had made some posts about my blend door actuator and my climate control module. I ordered a module off of Ebay and replaced it, as well as a new blend door actuator. Everything was fine for a few minutes and then the climate controls kept shutting off. NO a/c, heat or anything. I would turn it back on and it would go off again. sometimes it wouldn't come back on at all unless I restarted the car. the stupid actuator clicks once, im so sick of replacing it. why does the climate control keep shutting off? when I got the part in the mail, it said on the receipt that it was originally off of a 2009 mustang.
please help, this is depressing me
http://iihs.net/fsm/?dir=332&viewfil...l%20System.pdf
You can read through that and maybe it'll help.
I'm not sure I'd ever buy a used actuator unless I couldn't possibly get a new one. Just seems like that's fraught with danger of it not working and/or causing more issues... not saying it did here, just.. that's my thought process on it.
Hope that manual bit helps for ya.
thank you. the actuator is new, but the control unit was used. I ended up putting my original control unit back in. but for some reason with the new actuator I am getting air through the vents and defrost at the same time. Im starting to think that I installed it wrong and that its not lined up.
