2006 Mustang Father & Son Online Build Project Journal
#101
The Analog Admin!
Received 2,992 Likes
How Funny I Was Just Going To Post an Old Taillight Mod I Did Early on With Tape Stripe I Did To Give Some Separation The Lights! Looks Like You Beat Me To It!
It Was Silver PinStripe Tape! And Here is When The Wife Took Out The New Stang and My Company Truck at The Same Time! It Pretty Much Ended The Newness of The Car!
KC
KC
m05fastbackGT (4/8/24)
#102
Happy Eclipse day everyone. After I finished my repenting I heard a noise at the door. Nothing like an Eclipse day mail call.
Like a lot of 05 through 09 Mustang owners I wanted to upgrade the look of the back end of my S197 and Vector taillights were in my sights. But after thinking about it I started to get turned off to the idea. Not that they are bad, quite the opposite, They are quite cool looking but it seems that everyone has them and I prefer to go the path less traveled when I can so... I decided to get these tail light bezels instead. They are very simple but really make the tail lights look more distinctive. And they are a small fraction of the cost of a set of Vectors. Now should I change my mind later its no big deal to switch, I mean these were only about $50... That won't break the bank
#103
KC
KC
#104
With the next project we are turning our attention to the back of our Mustang and replacing the standard rear wing with a Duckbill spoiler
Before
For those that aren't familiar with the process. The stock wing is attached with 4 bolts and some adhesive.
Since the adheasive was only recently applied when they repainted the deck lid it felt like it was not so bad to remove. I mean it still took time but wasn't as bad as I expected. Basically we just used rubbing alcohol and some elbow grease
After about 40 minutes of work
With the new spoiler in place. The new spoiler only uses two bolts rather then the original 4 and 3M tape all around the perimeter of the spoiler
While this looks fantastic, it reduced visibility out the back window by about half... This could bite me in the butt at some point but right now I really dig it
Thanks for taking the time to look at our project
Before
#105
I thought about the GT500 spoiler and hindsight being what it is should have gotten that one instead if anything because of the visibility aspect. That said I do like the look of the duck.
As for the car with no spoiler I believe that is how the Bullitt cars came. Not sure I like the look without the spoiler but should the opportunity present itself to get a Bullett, I wouldn't turn it down because of the lack of a spoiler...
m05fastbackGT (4/9/24)
#106
You're exactly 100% spot about the 2008-09 Bullitt edition... Also, the 2007-08 Shelby GT models did not come with factory rear spoilers... Although, I wouldn't mind the look of having no rear spoiler on my 2006 GT, it would be too much of a hassle trying to locate a replacement decklid which doesn't include the rear spoiler, so I'll just stick with my OEM spoiler and just leave it as is...
Rear profile of 2007 Shelby GT
Side profile of 2007 Shelby GT
#108
The Analog Admin!
This Was Back in 08 But I Know The Spoiler Delete & Hole Plug Question Came Up Even Earlier Than That. Just For Information Sake There Are Plug Kits out There But This Home Brew Looks Better Than What I Have Seen!
https://themustangsource.com/forums/...2/#post5651019
#109
Received 2,283 Likes
Originally Posted by dirkpitt289
WOW, that looks fantastic. Thanks for sharing it with us
#110
Your very welcome and my pleasure.
You're absolutely 100% spot on about the spoiler delete option back in the day and the aftermarket hole plug kits... However, I didn't like the appearance of those hole plugs... When you see the decklid from close up, it looks as though there are 2 small bumps on each side... So, in the end, I just decided to keep the OEM spoiler intact as is...
#111
The Analog Admin!
Personally, I Like Seeing My Spoiler & Stripes in The Rear View! Reminds Me What I'm Driving!
KC
KC
#112
Same here, which is the main reason I decided in the end to just stay with the OEM spoiler.
#113
Today the boy and I are off to the Raceway Park swap meet. This is an event my friends and I went to for years when were were teens. Not sure what we will find if anything but will still be another great father/son bonding event.
#114
The Analog Admin!
Special Event Regardless of If You Find Any Parts! The Journey is the Joy!
Kc
Kc
#115
Exactly my thoughts as well!
#117
Knowing that you and your son had a good time together is priceless, as nothing can take away the bond between a father and son.
#118
Here is another project we did to help make our car stand out a bit. This car came with the matte black dash pieces. I was hoping to add the carbon fiber overlay but, EVERYONE does carbon and I want to try and stay away from what everyone does when I can. Another issue I noticed, was those that added the carbon overlay, the over lay was very thick and they all seemed to fall off months after they were applied. Well I found this Honeycomb overlay which I have yet to see anyone use. So I took a chance. Not only is the Honeycomb effect fantastic its very thin. I have a good feeling about this material and that is should stay in place for a long time
Before
At first I was worried that the kit I bought would not have the proper pieces for an aftermarket radio, which is what I have. This good news is the kit comes with the pieces to do the stock radio or and aftermarket radio like I have.
After
I also bought a emblem for a 66 Mustang Glove Box, cut off the posts and mounted it to the dash.I really think this sets off the dash
So today was the day to dive into the dash and console to try and find the wire harness for the MyColor cluster. Long story short, There was no harness for me behind the dash and or console.
Before
After
#119
Nice job it's looking great!
