1st oil change...500 miles
Old 3/29/07 | 03:06 PM
YaoNYC's Avatar
hello all,
im about to reach 500 miles.
should i change the oil?
thanks!
Old 3/29/07 | 03:11 PM
65205's Avatar
We always do. I've heard of some changing it at 50 and then 500.
Old 3/29/07 | 03:31 PM
Mustangfreak's Avatar
This is what I plan on doing. I'm going to buy some of these to put on the oil filter. And use this method to break in my motor.
And after 100 miles I'll change the oil, then at 500, then at 3,000.
Old 3/29/07 | 03:35 PM
YaoNYC's Avatar
thats really cool! how many are you going to get? i should do this too...
im at 400 miles now....i hope im not too late!
Old 3/29/07 | 03:36 PM
RobK's Avatar
Anyone know Ford's recommendation? I wouldn't get too aggressive. They usually fill the crankcase with break-in oil that's fortified with additional additives not found on off the shelf oils.
Old 3/29/07 | 03:57 PM
Mark S.'s Avatar
I changed mine at 650 miles and then I changed it at 3,650 miles (I will continue to change it every 3K miles...out of habit)...
Old 3/29/07 | 04:17 PM
karman's Avatar
Here are some interesting links:
http://forums.bradbarnett.net/showth...ght=oil+change
Old 3/29/07 | 06:28 PM
10 should be good.
Old 3/29/07 | 06:54 PM
kevinb120's Avatar
Heh, I did a big Boyd Coddington smokey burnout with it in the parking lot banging the rev limiter with 5 miles on it
Old 3/29/07 | 06:56 PM
kevinb120's Avatar
I believe that was the 1969 models
Old 3/29/07 | 07:31 PM
RobK's Avatar
At least one person was paying attention! The truth is today's motor really don't need a break in. Everything is so tight and seals so well it's not really necessary. I'll bet there isn't any break in recommendation at all. The comments above are correct however regarding the switch to synthetic. You do want to give everything a chance to seat 100% before switching. Synthetic is so slick and effective that it will literally prevent rings from sealing properly.
Old 3/29/07 | 07:58 PM
kevinb120's Avatar
You should always run it pretty hard when new though.
Old 3/29/07 | 08:13 PM
RobK's Avatar
Agreed. It's best to use like you intend to use it from day one.
Old 3/29/07 | 09:02 PM
HEADACHEZ's Avatar
I beleive I read some where in the owners manual that the break in period is about 1000 miles. As far as changing the oil at 500 miles, WOW, not sure about that but whatever works. I have a little over 500 miles right now, I plan on changing it somewhere around 1500 and then again 5000.
Old 3/29/07 | 09:21 PM
karman's Avatar
I was gonna say that, but I didn't want to upset anybody.
I waited all the way until 2000mi. to change mine.
Old 3/29/07 | 09:26 PM
HEADACHEZ's Avatar
Who knows I might wait that long too
Old 3/29/07 | 09:41 PM
The Reverend's Avatar
The filter is super glued on from the factory. I took a screwdriver and a hammer to it in order to remove the filter. Good luck with the oil change.
Old 3/29/07 | 10:04 PM
cookiemonster's Avatar
Exactly what I'm doing ... except I'm using the ForceField magnetic filter.
Old 3/29/07 | 10:14 PM
YaoNYC's Avatar
hi cookiemonter..really!
so far so good? you seeing a lot of particles coming through?
Old 3/29/07 | 11:06 PM
So far so good ... I saw what looked like glitter in the oil when I had it changed at ~50 miles.
