1st oil change...500 miles
Old Mar 29, 2007 | 02:06 PM
YaoNYC's Avatar
hello all,
im about to reach 500 miles.
should i change the oil?
thanks!
Old Mar 29, 2007 | 02:11 PM
65205's Avatar
We always do. I've heard of some changing it at 50 and then 500.
Old Mar 29, 2007 | 02:31 PM
Mustangfreak's Avatar
This is what I plan on doing. I'm going to buy some of these to put on the oil filter. And use this method to break in my motor.
And after 100 miles I'll change the oil, then at 500, then at 3,000.
Old Mar 29, 2007 | 02:35 PM
YaoNYC's Avatar
thats really cool! how many are you going to get? i should do this too...
im at 400 miles now....i hope im not too late!
Old Mar 29, 2007 | 02:36 PM
RobK's Avatar
Anyone know Ford's recommendation? I wouldn't get too aggressive. They usually fill the crankcase with break-in oil that's fortified with additional additives not found on off the shelf oils.
Old Mar 29, 2007 | 02:57 PM
Mark S.'s Avatar
I changed mine at 650 miles and then I changed it at 3,650 miles (I will continue to change it every 3K miles...out of habit)...
Old Mar 29, 2007 | 03:17 PM
karman's Avatar
Here are some interesting links:
http://forums.bradbarnett.net/showth...ght=oil+change
Old Mar 29, 2007 | 05:28 PM
10 should be good.
Old Mar 29, 2007 | 05:54 PM
kevinb120's Avatar
Heh, I did a big Boyd Coddington smokey burnout with it in the parking lot banging the rev limiter with 5 miles on it
Old Mar 29, 2007 | 05:56 PM
kevinb120's Avatar
I believe that was the 1969 models
Old Mar 29, 2007 | 06:31 PM
RobK's Avatar
At least one person was paying attention! The truth is today's motor really don't need a break in. Everything is so tight and seals so well it's not really necessary. I'll bet there isn't any break in recommendation at all. The comments above are correct however regarding the switch to synthetic. You do want to give everything a chance to seat 100% before switching. Synthetic is so slick and effective that it will literally prevent rings from sealing properly.
Old Mar 29, 2007 | 06:58 PM
kevinb120's Avatar
You should always run it pretty hard when new though.
Old Mar 29, 2007 | 07:13 PM
RobK's Avatar
Agreed. It's best to use like you intend to use it from day one.
Old Mar 29, 2007 | 08:02 PM
HEADACHEZ's Avatar
I beleive I read some where in the owners manual that the break in period is about 1000 miles. As far as changing the oil at 500 miles, WOW, not sure about that but whatever works. I have a little over 500 miles right now, I plan on changing it somewhere around 1500 and then again 5000.
Old Mar 29, 2007 | 08:21 PM
karman's Avatar
I was gonna say that, but I didn't want to upset anybody.
I waited all the way until 2000mi. to change mine.
Old Mar 29, 2007 | 08:26 PM
HEADACHEZ's Avatar
Who knows I might wait that long too
Old Mar 29, 2007 | 08:41 PM
The Reverend's Avatar
The filter is super glued on from the factory. I took a screwdriver and a hammer to it in order to remove the filter. Good luck with the oil change.
Old Mar 29, 2007 | 09:04 PM
cookiemonster's Avatar
Exactly what I'm doing ... except I'm using the ForceField magnetic filter.
Old Mar 29, 2007 | 09:14 PM
YaoNYC's Avatar
hi cookiemonter..really!
so far so good? you seeing a lot of particles coming through?
Old Mar 29, 2007 | 10:06 PM
So far so good ... I saw what looked like glitter in the oil when I had it changed at ~50 miles.
