05/06 Thermostat Relocation
Old 8/22/16 | 01:15 PM
Jeff2005's Avatar
Edelbrock sells a kit (15804) for $173 that replaces all hoses and housing and t-stat and moves t-stat from cold to hot side, but is just adding a universal inline housing on the hot side an ok alternative?
If I install a second t-stat housing on the hot side and move the t-stat from cold to hot side, can I leave the empty cold side housing in place?
Old 8/22/16 | 01:17 PM
I never heard of this. What would be the advantage?
Jeff2005 (8/22/16)
Jeff2005's Avatar
No sc btw, just a daily driver in the az sun
Old 8/22/16 | 01:20 PM
Jeff2005's Avatar
2007 ford moved the t-stat from cold side to hot side so the t-stat operates from engine coolant temp instead of radiator temp. The t-stat would open sooner and respond to engine temp.
Old 8/22/16 | 01:25 PM
Jeff2005's Avatar
Better design, but not much advantage on na to justify $173. Adding a 2nd housing and just moving the t-stat over much cheaper if it's OK to leave old housing in place.
Old 8/22/16 | 06:32 PM
I have an 07 and when I put the Saleen sc on it I had to convert the t stat and plumbing from the 07 up style to the 05-06 style because the Saleen SC was designed based on the 05-06 plumbing.
FWIW
I don't know that there's any advantage. You could upgrade your radiator or go with the 13-14 GT500 cooling fan. Which I've also done. The fan just drops in place and connects like the old one. The blade design is better and moves more air.
Jeff2005 (8/22/16)
Old 8/23/16 | 07:52 AM
Nice tip on the fans ? /\
Burnhaven
05-09 Interior and Audio Mods
12/3/16 12:46 PM
skistoy
10/21/16 08:23 AM
EPAS Performance
8/5/16 03:15 PM
jnnielson
7/26/16 07:20 PM
