Would this work?
Old 7/23/06, 02:17 PM
Kreiger's Avatar
Would this work?
I've wanted to install the mach 1 hood scoop to my car. It really was't hard to find.
http://store.summitracing.com/partde...5&autoview=sku
But, after researching it a little more, I really don't want to have to cut a hole in the hood. And I really don't like the way it looks unless you have the hood that came on the mach. Now I found this hood:
http://www.partstrain.com/products/A...ml?sku=F130115
Would it work if I bought the scoop and the hood or would I have to do something else?
Old 7/24/06, 05:13 AM
mudshuvel319's Avatar
With the screen in the recessed area, it looks like it was designed to work with a functional hood scoop rather than your shaker intake. If you were to take the black panel out of you stock hood scoop, you could then put in on the hood you found online and actually have air funnelled into the engine bay. I dont know how well it would work, but that's what it looks like it's designed to do.
If you wanted to use that online hood, you'd have to cut out the screen, but before you buy it, make sure that the hole is the same size as the shaker intake. It's a good looking hood and it has the same shape as the mach hood, so it should look pretty nice. Good luck!
Old 8/1/06, 11:32 PM
93cobrastang's Avatar
welcome to the forum....Classic Design Concepts (CDC) used to sell a kit
check http://www.classicdesignconcepts.com/ for details....
For The Hood check http://www.mpsautosalvage.com/ they usually have alot hoods so even if the don't have a mach 1 hood you can buy a stock hood and cut it
09-gt/cs
10/15/15 10:03 AM
Antigini-GT/CS
10/5/15 09:43 AM
Christopher Fox Wallace
9/26/15 11:55 AM
9/24/15 08:15 PM
Quick Reply: Would this work?
