Will a 550 lift cam work with stock valve springs in a 2003 GT?
Old Mar 31, 2012 | 02:31 AM
dtpugh's Avatar
Just put comp cams in my motor, it's a .550 lift, I bought the valve springs but they weren't put in. Will I be safe running it like this if I still shift at 5800rpms, give or take a few?
Old Mar 31, 2012 | 03:04 AM
AlsCobra's Avatar
A Man Just Needs Some....
I would call comp cams for that info. I'm sure they have a tech line you can call.
Old Mar 31, 2012 | 07:50 AM
Onesickstang01's Avatar
Comp will tell you that you need them. To be safe you really should install them. If you have any questions nick at modular head shop is the one to speak with. The guy is a genious when it comes to heads/cams
Old Apr 3, 2012 | 08:40 PM
stephen utley's Avatar
Stock springs will work fine kept rev limit stock i run MHs stage 3r with stock springs the cam is slimmer to comps 278 cam stock lift is 505 and 531 stock spring can go to 550
Ecostang
Nov 3, 2022 08:50 PM
tdf017
Aug 5, 2015 10:13 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 07:40 AM
LuiG31
Ecoboost
Jul 20, 2015 01:25 PM
