Wheel shake problem PLEZ HELP !!!
Old Sep 28, 2009 | 02:06 PM
stang23456's Avatar
My wheel shakes from 40-55 mph. I have an 04 GT and cant seem to figure problem out. I have been to the tire place about ten times now, seriously, and cant find the problem. Brand new tires, stock rims, which arent bent, all suspension is fine. Tires have been road balanced and are exactly on. Very frustrating problem which only occurs on low speeds 40-55. I even had my front rotors re surfaced. PLEZ HELP !!!
Old Sep 28, 2009 | 05:11 PM
MARZ's Avatar
Swamp Donkey Aficionado
This was an issue on my 2007 GT, so I understand how frustrated you must be. Have you checked to make sure that the brake retaining clips have been removed?
Old Sep 28, 2009 | 05:17 PM
stang23456's Avatar
yes, rotor clips removed !
Old Sep 28, 2009 | 07:36 PM
houtex's Avatar
I had said 'driveshaft' but then figured out "Oh, steering wheel." To which I'd add 'check the alignment, and although you've been to the tire store 10 times, check the amount of weight on the wheels... if there's a lot on one, then flip the tire 180 and see if that doesn't fix it.
Also... does it matter which wheels are on the front? Have you looked inside for mud?
Not that you'd be muddin' but just sayin'. Maybe someone's having fun at your expense.
Old Oct 1, 2009 | 08:34 AM
garagewear's Avatar
Find someone in your area that does tire truing. Most tire shops quit doing it because it cut down on the number of tires they sold but in reality every tire should be trued when it is put on a rim. The rim may balance and the tire may balance on the rim but it still does not mean it is true. Think about it ... every race team trues its tires before they ever hit the track. Most people think that truing or shaving is taking life off of a tire but it is making it round thus making it ride smoother and wear even.
Bill
05GT4.6
Sep 7, 2015 11:06 PM
salazamk
Aug 22, 2015 02:19 PM
MRGTX
Aug 21, 2015 08:49 PM
robjh22
4.6L GT Modifications
Aug 13, 2015 02:56 PM
trackpack13gt
Jul 23, 2015 11:13 PM
