Vortech first start
Old Dec 24, 2010 | 06:03 PM
scooter3's Avatar
Vortech first start
Here is a qucik clip of the first start up of the V2 SQ. Had a couple of issues so we still need to replace the injectors, install the IAT and get it tuned.
http://www.youtube.com/watch?v=P-ouAyh0C9M
Old Dec 25, 2010 | 03:25 PM
ShowGT's Avatar
I thought the kits came with new injectors, fuel pumps and fuel rails for applications... Do tell, sounds good.
Old Dec 26, 2010 | 09:09 AM
scooter3's Avatar
There are two kits, tuner kits and complete kits. This is a complete kit that I put together. Saved me some money that way. Problem being is that the injectors I originally bought that I was told were 42#, were actually 13# so the car would not stay running. So I had to scramble to get another set of injectors. Since the 90MM MAF does not have an IAT sensor that has to be drilled into the intake tube. There was a lot more to the build then I originally anticipated so that is why the delay.
Old Dec 26, 2010 | 10:54 AM
ShowGT's Avatar
Understandably. Clean car no doubt.
Old Dec 26, 2010 | 11:04 AM
tacbear's Avatar
You will love it when you get it going. I hope you have good reflexes...1st gear lasts about 1.5 seconds
Old Jan 5, 2011 | 04:10 PM
shaunrc's Avatar
How much did it run you
Old Jan 7, 2011 | 11:01 AM
scooter3's Avatar
You can actually piece it together for about a 1/3 less then buying it as a kit. I picked up a used headunit and other items, but did buy some new stuff. Here is a quick run down on what items I had to get and what each one cost. There are a lot of forums where you can buy some good stuff.
Total was about $2400 give or take a few bucks NOT including a tune.
Used Headunit V2 SQ 875.00 Used
39# Injectors 150.00 Used
GT fuel pump 150.00 New
90mm MAF 100.00 New
Bracket assembly 269.00 New
Discharge assembly 199.00 New
Air Intake assembly 215.00 New
Oil feed line 24.00 New
Oil drain line 24.00 New
3.6 Pulley 74.00 New
Pulley retainer assembly 12.00 New
NGK TR6 V plugs 16.00 New
75MM BBK TB/plenum used 200.00 Used
EV1 to EV6 adapters 29.00 New
AIT sensor 45.00 New
Oil and Filter 42.00
09-gt/cs
Oct 15, 2015 10:03 AM
GLOCKer
Sep 28, 2015 05:20 PM
tacbear
Sep 27, 2015 12:57 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
