Typhoon intake on a 1998 npi engine.
Old Jan 30, 2012 | 11:13 AM
woodybunch's Avatar
I found a deal that I can't pass up on a typhoon intake for a 1999 -2004 mustang. The first question is can I bolt this to my npi heads on my 98 via the way everyone is saying it can be done with a stock pi intake? Second if I change heads and cams to the standard pi's how much more hp will I get from it. I seen that a full pi swap brings about 40-50 rwhp. And I assume 20 or so is from the intake. The description on the typhoon says a dyno proven 20+hp. So I am also wondering is it worth it to change the heads and cams for only 20 hp?
Old Jan 31, 2012 | 07:54 PM
White94GT's Avatar
Well you won't see the full 20+ hp unless you have all the supporting mods which would be , upgrade mass air , throttle boby, heads and Cam!!!! ...
White94GT's Avatar
Throttle body*
blackhawkkid308
1994-2004 V-8
18
Dec 22, 2015 03:17 AM
blackhawkkid308
Sep 30, 2015 04:04 PM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
