Turn signals dont work!
so as it says my turn signals don't work...not in the dash, nor exterior the car. hazards don't work either....and my steering wheel controls for cruise control doesn't work either. My dash is also slightly dimmer in some areas as well. I had just upgraded my clutch with a couple other parts...I also put the svt decal on my tach....everything worked perfectly fine before the clutch and decal. so clearly I messed something up but what? haha obviously im assuming its from when I took the gauge cluster out but any help is appreciated....my cobra is running great with the new clutch and I just wanna enjoy it to its new potential and be able to turn properly according to the law.
Yeah I went back and unplugged and plugged back in the 2 big connectors and the hazards still don't work as well with the cruise control....I haven't checked the fuses yet just because of the fact there was no issue whatsoever before I put the decal on....a fuze can blow from something as simple as me just unplugging the gauge cluster?
Ok I found the problem....fuse #9 which is the "BOO and electronic flasher" 15A fuse...that bad boy was toasted...BUT I used the 15A fuse from my radio and figured I'd just use that for the time being and it worked right after I put it in but once I started the car...burnt again.....any takers on the issue? Ha
Michael Follett
7/24/15 06:58 AM
