Turn signals dont work!
Old May 2, 2013 | 10:22 AM
staakattack's Avatar
so as it says my turn signals don't work...not in the dash, nor exterior the car. hazards don't work either....and my steering wheel controls for cruise control doesn't work either. My dash is also slightly dimmer in some areas as well. I had just upgraded my clutch with a couple other parts...I also put the svt decal on my tach....everything worked perfectly fine before the clutch and decal. so clearly I messed something up but what? haha obviously im assuming its from when I took the gauge cluster out but any help is appreciated....my cobra is running great with the new clutch and I just wanna enjoy it to its new potential and be able to turn properly according to the law.
Old May 2, 2013 | 10:42 AM
shurtual86's Avatar
Did you check the fuses already? Did you plug in connectors in the gauge cluster all the way in? Just some things I would try first.
Old May 2, 2013 | 12:33 PM
td01gt's Avatar
turn signals not working
Plus 1# on rechecking your connectors. Also check out your hazard flasher.
Old May 2, 2013 | 01:06 PM
Yeah I went back and unplugged and plugged back in the 2 big connectors and the hazards still don't work as well with the cruise control....I haven't checked the fuses yet just because of the fact there was no issue whatsoever before I put the decal on....a fuze can blow from something as simple as me just unplugging the gauge cluster?
Old May 2, 2013 | 01:32 PM
td01gt's Avatar
the fuse could have been on it way out. i donot think you cuase it. the part i was saying to also check control the hazard flasher.i may not be using the correct name.
Old May 3, 2013 | 06:35 AM
Ok I found the problem....fuse #9 which is the "BOO and electronic flasher" 15A fuse...that bad boy was toasted...BUT I used the 15A fuse from my radio and figured I'd just use that for the time being and it worked right after I put it in but once I started the car...burnt again.....any takers on the issue? Ha
Old May 3, 2013 | 09:07 AM
shurtual86's Avatar
Something is incorrectly wired, I think a ground and power wire got mixed up somewhere. Recheck your wiring.
Old May 4, 2013 | 03:28 PM
Found the sucker, apparently another thread I found had the same exact issue. Thanks for the help guys
HizliBullet
GT350
14
Nov 14, 2015 08:59 AM
mbowling
Jul 26, 2015 07:38 PM
Michael Follett
Jul 24, 2015 06:58 AM
Kev006
Jul 8, 2015 05:29 AM
