Trick Flow 2v SOHC 4.6 head
Stubborn Bear
TMS Staff
TMS Staff
Acctually you should make really good power. The 96-98 cars had flat pistons so when they would swap to the 99+ PI heads, they made more power than teh 99-04 cars did with teh same heads. The flat pistons created a higher compression ratio. Now I dont know how they are addressing this on the Trick Flow pieces, but regardless you should be better off.
Needs to be more Astony
I read more about the trickflow heads and they are offereing them in a larger chamber size for the 96-98 guys so compression won't go up if you buy that version.
