throtle body
Old May 31, 2005 | 09:25 PM
Rockford's Avatar
I have a 2001 mustang gt about a year ago i replaced the throtle body with a 70mm acufab then but a bbk cold air induction kit on and just recently i put a trick flow upper plentum on and then yesterday i raced a buddy with a 2002 mustang gt and all he has is a cold air induction kit and he kept up with me my question is do i need to reset my computer to tell my computer on my car or what or was the $600 dollars in improvements a waste and shouldnt i notice a big difference please tell me. Thanks for your time...
Old May 31, 2005 | 10:02 PM
The Rock 326's Avatar
A tune wouldn't hurt. I picked up a good bit by getting a tune. Without a tune, your gains would be minimal, IMO.
Old Jun 1, 2005 | 07:51 AM
joker's Avatar
Yep, I am with Rock. Gains for a throttle body and plenum are going to be very minimal on an otherwise stock engine. A tune would help some. Also, you didnt mention what transmissions both of you are running. If he is in a 5 speed and you in an auto then the drivetrain loss in the auto would more than cancel out the gains from those two mods against a 5 speed. And there is always the possibility that he just drives better than you as well.
Old Jun 1, 2005 | 09:18 PM
Fordracing200's Avatar
Old Jun 4, 2005 | 05:27 AM
conv_stang's Avatar
id say its probably just get got a better run than you. it happens, i lost to my friend in his bonestcok 91 lx b/c i bogged on the line
Old Jun 5, 2005 | 12:51 PM
SoCalCobra311's Avatar
installed a 70MM BBK TB and im getting a check engine light and the car is ideling all over that RPM range. It will start up and stick about about 2k then drop back down to one. getting a code error for the Throttle Postion Sensor. Reset my computer and its still acting up :angry:
edit:
figured out what the problem is. I forgot that I had a spacer on my accelerater pedal to take up the slack, because on a stock mustang in atleast my year, the pedal is real close to the ground not allowing wide open acceleration. So when I installed the TB it needed a little more slack which I did not have because of the spacer. So the the TB was running slightly open at all time hence causing the car to idle high
kponypower
Jun 17, 2020 07:17 AM
GLOCKer
Sep 28, 2015 05:20 PM
seaclam
Sep 25, 2015 01:29 PM
