Supercharger and pistons
Old Feb 19, 2012 | 03:30 PM
White94GT's Avatar
Does anyone know if you can run a 6-8psi supercharger with (Cast Aluminum pistons)
Old Feb 19, 2012 | 04:10 PM
cpotts13's Avatar
You can run 40 psi, dosnt mean you should
Lol jk, I have no serious answer for ya
1999Pony's Avatar
I would say 4-5psi, but you could probably get away with 6-8 for a good while.
Old Feb 19, 2012 | 04:40 PM
tacbear's Avatar
I dynoed at 10psi and have gone 15,000+ miles since my SC was installed. I have about 50 passes at the drag strip. 40 laps at Barbers Motorsport Park. 10 laps at Talladega (topped out at 171). I have had NO problems, but I also have a conservative tune. (I have seen 14# of Boost on cold nights).
Attached Thumbnails Supercharger and pistons-100_3092-medium-.jpg   Supercharger and pistons-dsc_0462.jpg   Supercharger and pistons-100_2213improved.jpg
Old Feb 19, 2012 | 04:51 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
I'll verify tacbears car runs good. He's passed me more than once on the track
Old Feb 19, 2012 | 06:38 PM
cpotts13's Avatar
How much ho would a supercharger running that low psi net you?
Old Feb 19, 2012 | 06:41 PM
1999Pony's Avatar
Running about 6psi, probably in the 300 to the crank range on the 302
Old Feb 19, 2012 | 06:42 PM
cpotts13's Avatar
WB the 2v 4.6?
Old Feb 19, 2012 | 06:44 PM
Tommy d's Avatar
10 psi is fine for a 2v with tune ive seen people with 130000
Miles boosting hard with stock internals just get a good tune
Old Feb 19, 2012 | 06:45 PM
1999Pony's Avatar
tacbear's is 381 to the wheels at 10 psi so 340 at the wheels probably at 6-8psi. Somewhere in that range
Old Feb 19, 2012 | 06:46 PM
cpotts13's Avatar
On stock internals?
Old Feb 19, 2012 | 06:47 PM
1999Pony's Avatar
Yep. Its all about the tune though.
Old Feb 19, 2012 | 06:48 PM
Tommy d's Avatar
6 is low I would do 10 to 12 with a inner cooler would but you around 400 hp
cpotts13's Avatar
Niceeeee, so very conservatively 330 HP with a good tune, wouldnt kill anything?
Old Feb 19, 2012 | 06:49 PM
1999Pony's Avatar
Thats what Id do on a 2V. The OP has a 5.0 though and 6-8 is a good safe level on stock internals.
Old Feb 19, 2012 | 06:50 PM
1999Pony's Avatar
Wouldnt even stress it a bit.
Old Feb 19, 2012 | 07:02 PM
White94GT's Avatar
Well I have a stock 302 block bored .40 over to 308, edelbrock performer heads, performer intake, stage 1 cam, stock crank and rods, with new cast aluminum pistons and when I ordered the shortblock it said for N/A use. But my buddy is selling his vortech from his 95 gt, I just wanna see what you guys think?
Old Feb 19, 2012 | 07:24 PM
1999Pony's Avatar
I think you would be fine with it. Your compression is probably a little high for you to run alot of boost but its not gonna hurt anything. I still say you'd be good to around 300 or so
Old Feb 19, 2012 | 08:50 PM
tacbear's Avatar
With a 3.6" pulley(about 7-8psi), stock plastic intake pipe, 36# injectors and conservative tune will get you 340-360hp. With the 3.33" pulley, Power Pipe, 42# injectors and good tune (about 9-10psi) you should get you between 380 and 400hp. A 2v 4.6 won't live long pushing over 420 hp.
Road_Runner
Sep 2, 2024 04:46 PM
bones302
Oct 7, 2015 04:42 AM
JonathonK
Sep 19, 2015 03:19 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
