speedo problem
hi im new here, i own a 94 mustang gt and live in spain the car is actual a japonese motor manufactured for export to japan anyway i have a problem with the speedo it has stoppe dworking completely at the same time the aftermarket cd player has stopped and th eiarbag warning light has come on. any ideas wht it might be, the car did suffer a power surge that blew quite a few fuses ive replaced all that i can find but cant find out why i still have this problem
many thanks in advance
Welcome to the site Slaine.
Does any of the other instrument cluster guages work?
There is a fuse box under the dash and under the hood. The dash one is able to be seen if you lay down in the drivers floorboard and look up. Just pop the plastic cover off and you can see it all.
The other is under the hood next to the battery.
Since you mentioned a power surge, those would be the first and easiest things to check. Just making sure you got them all.
ive checked all the other fuses and can find non at fault i have no other instrument problems. It would help if i could get a diagram of which fuses do which in both fuse boxes any ideas where i might find this on the web, as getting hold of anything over here is extremely difficult
many thanks for your help in advance
all the best slaine
all the best slaine
This should help, and Hello and Welcome.
http://autorepair.about.com/library/illust.../bl045a-lib.htm
thanks that was a great help by the way i thought you might like to see some pics of the old girlby the way how do you add pics?
for now these links will have to do
sorry ignore me found the button
thats my warning light for when it takes off
nah seriously its due to the UK road laws, your right it is a fog light and for a reason that im not total sure about at the moment apparently US vehicles lighting on the rear doesnt conform with UK road law and so a seperate rear fog light must be added
Rando
Aug 25, 2021 11:12 AM
