Slight moan coming from rear-end.
Old Mar 22, 2005 | 08:48 AM
KansasCityTim's Avatar
I have a '98 GT, and at low speeds, I get a moan that is coming from the rear-end of the car. Has anyone had this problem? I am thinking it could be a rear-end bearing, but that is only a guess.
Old Mar 22, 2005 | 10:38 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
Sounds like it could be a bearing starting to wear out causing parts to not line up properly.
Old Mar 22, 2005 | 11:43 AM
QWKSNKE's Avatar
Has anyone performed a gear install? How many miles are on the rear end?
Most bearings in the rearend will last well over 100k miles BUT I have seen a couple of pinion bearings go out a little before. If someone has done a gear change or if you race a good bit, it could be a number of things. bearings, improper gear lash, or bad 'spider' gears
Old Mar 22, 2005 | 12:03 PM
Car's got 97k on it. As far as I know, it has never had anything done to the gears. I have had it since 20k miles. I was thinking pinion bearing as well. Anyone know how much that will cost? I mean is it a huge ($1000+) job, or something more minor.
Old Mar 22, 2005 | 05:30 PM
QWKSNKE's Avatar
i don't know what rates are where you live, but a pinion bearing is about $10-$15 and I personally would charge about $100 labor
Old Mar 22, 2005 | 05:31 PM
QWKSNKE's Avatar
If you have access to a press, you could do it yourself
Old Mar 24, 2005 | 06:32 AM
Nuts4Ford's Avatar
I just started to hear something similar to that in my 98 GT. It sounds like a lower tone break squeal. Mostly at low speed and when I turn. Could it be the same problem?
Old Mar 24, 2005 | 05:42 PM
I took mine to a mechanic, had the diff cover pulled, and checked all the bearings, gears, the motion, etc. and found nothing. It has been doing it for a year, and the guy told me if it were a bearing or something, it would not come and go as it does, and further, it would not last a year. He came to the conclusion that I had glazed a brakepad, which is causing the sound. I am fairly certain at this point it is not the rear end, or any wheel bearings for that matter. At some point when I have time, I am going to take off the rear pads and lay a quick piece of 120 sandpaper to them to try and knock any glaze off of them.
By the way, what you described is identical to what I have going on.
Old Mar 24, 2005 | 06:05 PM
foxhtn's Avatar
sounds like brake dust. Just haul the wheels and drums off, and take an air hose to it.
Old Mar 24, 2005 | 07:39 PM
Originally posted by Merlot+March 24, 2005, 7:08 PM--><div class='quotetop'>QUOTE(Merlot @ March 24, 2005, 7:08 PM)</div><div class='quotemain'><!--QuoteBegin-Nuts4Ford@March 24, 2005, 7:35 AM
[/b][/quote]
Don't have drums.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Sep 30, 2015 07:02 PM
