Seafoaming
Old Dec 13, 2011 | 06:57 AM
Dbranham's Avatar
Seafoaming
Anyone use seafoam? Anyone use it on a cobra?
Old Dec 13, 2011 | 07:08 AM
CCTking's Avatar
Hvnt on a Cobra but i did use it on my 02 gt. cleaned her up good, and i actually felt a difference. After treatment and getting all that smoke out of the pipes you gotta driver a lil hard to get any remaining gunk and fluid out. Plenty videos on youtube of how to do it
Old Dec 13, 2011 | 07:14 AM
Dbranham's Avatar
I can't seen to find a video with a cobra being seafoamed(how to do it). Any problems with o2 sensor?
Old Dec 13, 2011 | 07:42 AM
CCTking's Avatar
I never had any issues. In fact i had a check engine light on (nvr ran it for codes though) but after seafoaming the light went away.
Old Dec 13, 2011 | 07:52 AM
Dbranham's Avatar
Thanks! So pour some in vacuum line? Some in gas tank?
Old Dec 13, 2011 | 07:57 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
I seafood all my vehicles. Including my 1997 cobra.
Old Dec 13, 2011 | 08:00 AM
Seafood is awesome. I love shrimp and flounder.
Old Dec 13, 2011 | 08:03 AM
CCTking's Avatar
Yep! And some in your oil as well. What i did was fine measuring bottle and poured the seafoam in there. Put 1/3 of the bottle in the gas tank, 1/3 in the oil reserve, then have a friend help you for the last bit with the vacuum line. Makes it easier. Let the engine run for acouple minutes then turn it off. After bout 5 mins turn it on and rev the engine several times. Depending on how many miles u got or well maintained ur engine is your cars gonna smoke alot from the pipes. Rev it for a few minutes till the smoke starts clearing and then let it idle for a bit. (you can rev more this is just how i did it)
Then enjoy your newly cleaned engine (:
Oh and drive a lil harder next time you drive after seafoaming. Just to make sure you get everything out. Maybe 10-15 minutes of driving and youll be good to go
Old Dec 13, 2011 | 08:08 AM
Bear Eats King...
Bear ****s Bone
I will never add it to my oil.
It thins the oil out and can cause bearing damage. If you put some in the oil id put a very small amount.
Old Dec 13, 2011 | 08:10 AM
Bear Eats King...
Bear ****s Bone
While you are pouring the sea foam in, have some one kill it right before you finish pouring it in. For best results.
Old Dec 13, 2011 | 08:34 AM
Dbranham's Avatar
Plan on doing this tonight! By kill you mean stall right? Not just turn the key?
Old Dec 13, 2011 | 08:36 AM
Dbranham's Avatar
Should I record the process on how to do it? Cause I'm sure someone out there like me is looking for a guide on how to seafoam the cobras.
Old Dec 13, 2011 | 09:59 AM
Bear Eats King...
Bear ****s Bone
No. Turn the key. You don't want to stall it.
Old Dec 13, 2011 | 10:00 AM
Bear Eats King...
Bear ****s Bone
It's just like seafoaming any other car.
bluethunderhorse
Jan 3, 2017 10:22 PM
Topnosxrs
Jul 3, 2011 09:03 PM
Xeno
Jul 10, 2008 12:53 PM
MrClean
Jan 3, 2008 05:12 PM
MTAS
Nov 14, 2006 01:26 PM
