Removing door wire housing
I took my car into a hand wash car wash today but when I got home I noticed my power lock and window switchs were gone! I looked in the hole where they suppose to be and sure enough the were pushed down inside. Anyone know how I get to them? [img]style_emoticons/<#EMO_DIR#>/crying.gif[/img]
Not looked at my GT but most of the time its the same deal, remove the panel. Had to fix several windows over the years, i think you will have to remove all the screw covers from the trim (door handle etc - use a small flat screwdriver and be careful) remove all the screws and then the panel should just pop out with some force start at the edge and gently tease it along trying to keep it relatively straight so as not to snap/crease the panel. Will have to slide the panel carefully over the door handle. Try not to damage the plastic film on the door. Good opportunity to take a look at your window mechanics to make sure all good. I hope this information is correct (someone please correct if I am wrong) and helps you along. Should take about an hour total. Dont take to that car wash again, next time have some fun yourself.
ANYWAY HOW DID THEY MANAGE TO BREAK IT!!!!!!
<div class='quotetop'>QUOTE(Tiberius1701 @ February 16, 2006, 8:05 AM) Quoted post</div><div class='quotemain'>
Instructions in attached pdf...hope this helps!
[/b][/quote]
Matt, can you find me one on how to get at the door ajar switch?
J
[/b][/quote]
J
