Problem with Fuse box
Old Aug 13, 2011 | 04:49 PM
05Blackbeauty's Avatar
My son has a 96 GT and all of a sudden his wipers stopped working. I checked to see if the motor was bad by using a test light. It seems to be fine, but the problem seems to lie with the fuse itself. We get no "light" when we check the connector itself.
When we went to check on the fuse under the dash, I noticed that it was halfway out. When we pushed it back in, it just comes right back out. It is not staying in place. And yes it is still good fuse. (30amp per manual)
I think that the metal connectors that hold it in place may be either missing or maybe bent? How does one go about fixing this? Do we need to remove the battery and then remove the entire fuse box to fix it?
Sorry for all the questions, but I need to get this fixed ASAP as the "rains are a comin'" and he needs to drive his car to get to work, etc.
Old Aug 17, 2011 | 12:08 AM
Zrider07's Avatar
I'd still disconnect the battery but you shouldn't have to pull the fuse box. Is this the box in the engine bay or under the dash? I'm not too sure what sort of problems you would have if it's broken inside but if they're just a bit too spread out then you should just be able to take a pick or screwdriver and lightly push the prongs in so that they'll connect with the fuse again.
Rando
Aug 25, 2021 11:12 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
09-gt/cs
Oct 15, 2015 10:03 AM
tang65c
Oct 6, 2015 07:39 PM
boz
Oct 1, 2015 04:47 PM
