Pipe size?
Old Feb 23, 2013 | 04:27 PM
TheMuffinMan's Avatar
Pipe size?
Why do people put 3" piping on mustangs without having enough horsepower to need that size piping?
Old Feb 23, 2013 | 05:23 PM
yugoboss's Avatar
They think bigger is better.
Old Feb 23, 2013 | 05:29 PM
Even on the newer cars there not pushing enough HP stock to make 3" exhaust needed. Infact it could cause a loss in power.
Old Feb 23, 2013 | 09:45 PM
cpotts13's Avatar
I would say the gt500 warrants the 3inch exhaust. As for the 5.0 is say yes still. Because you can make 450 rwhp with bolt ons....
Old Feb 23, 2013 | 09:49 PM
I looked it up before I believe dual 2.5" piping is good till 600 not 450 though I could be wrong.
Old Feb 23, 2013 | 09:51 PM
cpotts13's Avatar
I could be wrong to, shooting in the dark here!
Old Feb 23, 2013 | 10:06 PM
Usually....3" piping is found on big trucks. I'm fairly certain you don't need 3" till your 600 or over, or have FI because FI increases the flow and volume. That isn't to say that N/A doesn't but not as much as FI would. It's something to look into and maybe a exhaust guru will reply on this post to clarify!
bluethunderhorse's Avatar
Dual 2.5 in pipes are good to around 475-500 hp. After that they pose a restriction. Too big of a pipe slows the exhaust gas velocity, which in turn kills any scavenging effect that is built into the system. Much the same way that too small of a pipe kills the flow rate
Old Feb 23, 2013 | 10:08 PM
Ah this sounds about right. I don't see why any mustang other than the GT500's and the new GT's would have 3" exhaust. Lets be real how many people who buy even the GT's mod it enough to get that much power out of it?
Old Feb 23, 2013 | 10:14 PM
You'd be surprised how easy it is to hit those numbers with a DOHC motor. My car gained 37 hp from just a tune. For some reason Ford put a very conservative tune on the Cobras
Old Feb 23, 2013 | 10:19 PM
cpotts13's Avatar
Yeah its crazy I added a few stickers and had to move up to 3" piping.
Old Feb 23, 2013 | 10:23 PM
I'm talking about GT's not cobras and GT500's I just throw the cobras in the same boat as the GT500's. for cobras you guys can reach that number easily from tune,exhaust and pully swap. The SOHC GT's won't reach this without building on the engine or FI. Most people just do bolt ons.
Old Feb 23, 2013 | 10:25 PM
Yes but the new GT's are 4V cars
Old Feb 23, 2013 | 10:31 PM
Yes the newer ones can boarder line 475-500 with bolt ons. I forgot to put that in my post. As you can see lack of sleep is getting to me at this point.
Old Feb 23, 2013 | 10:44 PM
steven46746's Avatar
My pipe is huge!!
Old Feb 23, 2013 | 11:50 PM
blairnr67's Avatar
Originally Posted by steven46746
My pipe is huge!!
Not what she said
Old Feb 26, 2013 | 04:00 PM
shaunrc's Avatar
Really its what you are aiming to do with the car. I don't know the math equation but its dependent on the piston size, compression ratio, bore size, what horsepower your aiming for at a specific rpm and it will give you your pipe diameter needed to obtain your goal I'm sure you could Google it
Old Feb 26, 2013 | 09:04 PM
1999Pony's Avatar
IME the majority of people run 2.5in piping through the exhaust and just put the bigger tips. Personally, I hate tips that big but it does help to reduce exhaust drone.
Old Feb 26, 2013 | 09:13 PM
cpotts13's Avatar
Im with you, i bought my catback specifically with the 3 inch tips to give it that sleeper exhaust look.. until you fire it up..
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
Sep 10, 2015 12:44 PM
Kestral
Sep 2, 2015 06:52 PM
