PCV confusion
If you are going to connect a breather to each valve cover just block off the line going into the intake manifold you won't need it anyway
Ok sounds like a plan...
Would these valve covers fit then? I know there for a carb but isn't the difference that it has one whole in EACH valve cover? If so it's already set for the breather set up....my only issue is I don't know the correct height I need
http://www.cjponyparts.com/ford-raci...-351w/p/VC105/
Correction I have a 95 cobra so it's a 5.0 not a 4.6. It should bolt up, just unsure about the height and if there's any legit difference other than the fact I have to run breathers with carb valve covers which is what id like to do because I like the way it looks and I read up that it's effective
Well there is 3 infront just like the ones I'm interested in getting...I'm not 100% sure because I'm on field training right now for 2 weeks but just worried about rocker clearance and intake clearance...maybe if someone knows or can tell me where I can find out the height needed and all that?
