PCV confusion
Old Jun 18, 2013 | 07:59 PM
staakattack's Avatar
PCV confusion
So I'm doing a turbo on my 95 cobra, would I be fine just running a breather on each valve cover and keep the pcv hose in the back of the intake hooked up?
Old Jun 19, 2013 | 09:58 PM
shaunrc's Avatar
If you are going to connect a breather to each valve cover just block off the line going into the intake manifold you won't need it anyway
Old Jun 20, 2013 | 05:15 AM
Ok sounds like a plan...
Would these valve covers fit then? I know there for a carb but isn't the difference that it has one whole in EACH valve cover? If so it's already set for the breather set up....my only issue is I don't know the correct height I need
http://www.cjponyparts.com/ford-raci...-351w/p/VC105/
Old Jun 20, 2013 | 09:17 AM
shaunrc's Avatar
Here's the problem on your 99 to 04 the valve covers are 11 bolt to 13 bolt depending on the year or romeo or Windsor block. If you look at those cobra ones they look like they have only 6 bolts.
Old Jun 20, 2013 | 10:05 AM
Correction I have a 95 cobra so it's a 5.0 not a 4.6. It should bolt up, just unsure about the height and if there's any legit difference other than the fact I have to run breathers with carb valve covers which is what id like to do because I like the way it looks and I read up that it's effective
Old Jun 20, 2013 | 10:23 AM
shaunrc's Avatar
My bad didn't see that oops anyway how many bolts do your valve covers have on them
Old Jun 20, 2013 | 10:45 AM
Well there is 3 infront just like the ones I'm interested in getting...I'm not 100% sure because I'm on field training right now for 2 weeks but just worried about rocker clearance and intake clearance...maybe if someone knows or can tell me where I can find out the height needed and all that?
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
robjh22
Dec 14, 2015 08:41 AM
Bryanh24
Oct 14, 2015 08:43 AM
Red Gt
Sep 22, 2015 12:31 PM
