Oil
Old Feb 21, 2012 | 07:00 PM
McNassty's Avatar
Oil
Okay stupid question but a 5.0 holds 5qts. Of oil right? I always empty both drain plugs and the oil filter completely and add 5 qts. And I always seem to have high oil pressure
Old Feb 22, 2012 | 01:26 AM
irishn8's Avatar
lubricants.s5.com/oil_pressure.htm
Maybe that will help?
Old Feb 22, 2012 | 01:48 AM
bob's Avatar
bob
What viscosity oil are you running?
The volume of oil in the pan shouldn't effect oil pressure unless its low. The oil pump ultimately determines oil pressure which can be effected by the state of the engine (worn engine components, quality of of oil system, et al).
Another component that can effect oil pressure is the bypass in the system. If the bypass doesn't open at the correct pressure then the oil system will operate at a higher pressure.
Beyond that, all I can think of is a faulty sensor.
Old Feb 22, 2012 | 06:31 AM
McNassty's Avatar
I run 10W 30 Royal Purple and I think when I bought her the previous owner may have mentioned a high volume oil pump
Old Feb 22, 2012 | 09:58 AM
irishn8's Avatar
Sounds like it was on purpose but from what I read, high oil pressure is very bad!
Old Feb 22, 2012 | 12:23 PM
McNassty's Avatar
It's not crazy high, it reads between the 'm' and the 'a' on 'normal' I was just wondering about it. Thank you for the link, it really explained a lot
Old Feb 22, 2012 | 12:37 PM
irishn8's Avatar
Something like that?
Np glad it helped.
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
