New clutch
Old Mar 1, 2012 | 08:19 PM
br23will's Avatar
New clutch
Just installed a new zoom high performance clutch. Now I have a shutter on take off and in reverse. I had the flywheel machined and all bearings replaced with install. Is this normal? Or is the something I can do to smooth it out?
Old Mar 1, 2012 | 08:22 PM
stephen utley's Avatar
Needs time to break in did u replace or resurface the flywheel
Old Mar 1, 2012 | 08:23 PM
br23will's Avatar
I had it resurfaced
Old Mar 1, 2012 | 08:24 PM
Never mind u did resurface the flywheel just needs to break in
Old Mar 1, 2012 | 08:27 PM
br23will's Avatar
I just put it in today. It just shakes quite a bit. I didn't know if that was normal
Old Mar 1, 2012 | 08:31 PM
Was the flywheel and disc clean when u in stalled it
Old Mar 1, 2012 | 08:40 PM
br23will's Avatar
Yes right out of the box. I made sure not to touch the surfaces
Old Mar 1, 2012 | 08:43 PM
Ian running a spec stage 2 shutter at first went away after about 600 miles
Old Mar 1, 2012 | 08:56 PM
br23will's Avatar
I'll see how it does after some miles
Old Mar 2, 2012 | 08:44 PM
br23will's Avatar
Could it be that the cable needs adjusted? It also doesn't engage until the pedal is half way up.
Old Mar 2, 2012 | 08:57 PM
Do still have the stock cable and quadrant
Old Mar 2, 2012 | 09:31 PM
cpotts13's Avatar
Half way up is how it should be. It needs to break in, so give it up to 1000 miles.
Old Mar 3, 2012 | 04:02 AM
br23will's Avatar
The stock clutch was lower to the floor
Old Mar 3, 2012 | 06:35 AM
cpotts13's Avatar
Then it wasn't how it should be.
Old Mar 4, 2012 | 08:55 PM
br23will's Avatar
It was that way from the factory
Old Mar 4, 2012 | 08:58 PM
cpotts13's Avatar
It should start biting half way from the ground, that's what I've always heard, and that's what a couple members here have said aswell. Mine bites half way, with a stock clutch.
Old Mar 4, 2012 | 09:02 PM
br23will's Avatar
Well maybe my description of halfway is different , idk. But it is now further up than my stock one. Is there a way to adjust it?
br23will's Avatar
Old Mar 4, 2012 | 09:37 PM
cpotts13's Avatar
Yes there is, although I have never done it so I can't really explain it, maybe someone can chime in?
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
JonathonK
Sep 19, 2015 03:19 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
