Need some help
Need some help
Have a 2001 Mustang GT Convt.
I have changed my fuel pump, I changed all 8 spark plugs and also all 8 ignition coils what else can I do...my car hesitates when I take off and studders a lot.
What can it be? What else can I do ?
Originally Posted by bluethunderhorse
most likely your mass air sensor is dirty or faulty
I would do the maf cleaning like the others stated. If it doesn't work then I would look into getting it checked on a computer and taken for a drive so they can check the paramiters, etc or some shops have a unit that will plug in and you can drive it for a day or two and it will log data. you could have a sensor that is a having a voltage issue or something along those lines that may be tricky to pin point.
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Advance auto parts has a cleaner spray that does the jobs nicely. Don't use brake parts cleaner it leaves a residue that will make your problem worse
![Lol](https://themustangsource.com/forums/images/smilies/lol.gif)
