Need some help
Old Mar 17, 2012 | 05:26 PM
Daniel D.'s Avatar
Need some help
Have a 2001 Mustang GT Convt.
I have changed my fuel pump, I changed all 8 spark plugs and also all 8 ignition coils what else can I do...my car hesitates when I take off and studders a lot.
What can it be? What else can I do ?
Old Mar 17, 2012 | 07:11 PM
sampey43's Avatar
Tried cleaning the throttle body?
Old Mar 17, 2012 | 07:51 PM
Daniel D.'s Avatar
Ok what would be the next step if that doesn't work.
I just don't wanna be spending a lot of money
Old Mar 17, 2012 | 08:34 PM
JDF's Avatar
JDF
Ad the idle air control as well as your mass air
Old Mar 21, 2012 | 06:59 PM
bluethunderhorse's Avatar
most likely your mass air sensor is dirty or faulty
Old Mar 22, 2012 | 04:17 AM
br23will's Avatar
No check engine light?
Old Mar 22, 2012 | 07:11 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
^this^
Old Mar 22, 2012 | 11:24 AM
Onesickstang01's Avatar
Also do fuel filter if you havent already
Old Mar 23, 2012 | 05:46 PM
White94GT's Avatar
+1 sounds like a dirty mass air sensor , my car was there the same thing when it was bone stock and once it was cleaned it was a night and day difference !!
Old Mar 23, 2012 | 06:50 PM
skunk21's Avatar
I would do the maf cleaning like the others stated. If it doesn't work then I would look into getting it checked on a computer and taken for a drive so they can check the paramiters, etc or some shops have a unit that will plug in and you can drive it for a day or two and it will log data. you could have a sensor that is a having a voltage issue or something along those lines that may be tricky to pin point.
Old Mar 27, 2012 | 01:38 PM
01bullitt's Avatar
How do you clean,the maf??
Old Mar 28, 2012 | 08:14 PM
Advance auto parts has a cleaner spray that does the jobs nicely. Don't use brake parts cleaner it leaves a residue that will make your problem worse
Old Mar 28, 2012 | 08:20 PM
Bear Eats King...
Bear ****s Bone
I use brake clean all the time.. read the can. A good quality brake clean states on the can that it leaves no residue.
Old Mar 28, 2012 | 11:51 PM
shaunrc's Avatar
What mods do you have done and what type of fuel are you running
