Mustang Shakes
Jack the front end up and check side to side and top to bottom movement on the front tires. Just grab the tire on each side and see how much it moves before the tire on the other side moves. Do the same by grabbing the top and bottom of the tire and moving it in and out. There a pretty good you tube vid checking ball joints and tie rod ends. I don't have time to go and find it for you though. If that all seems like its pretty tight take one front tire and put it on the rear and see if you have the same problem. if you do swap the other front tire o the back. let us know what you find.
7/20/15 06:26 AM
