Mustang Shakes
Old Jul 30, 2013 | 05:03 AM
04desire's Avatar
Mustang Shakes
When I drive about 55 mph she starts to shake. Feels like the whole car and the steering wheel. Any idea whats going on.
Old Jul 30, 2013 | 06:34 AM
AzPete's Avatar
Check the tire balance. They can also verify if a tire is separating or if a wheel is bent/damaged. Next would be looking at the drive shaft.
Old Jul 30, 2013 | 08:54 PM
houtex's Avatar
Alignment can cause this too, if the caster or toe is messed up. Which could mean something bent/broken/worn in the suspension. Probably not it, but throwin' it out there in case.
Old Jul 31, 2013 | 07:13 AM
Jack the front end up and check side to side and top to bottom movement on the front tires. Just grab the tire on each side and see how much it moves before the tire on the other side moves. Do the same by grabbing the top and bottom of the tire and moving it in and out. There a pretty good you tube vid checking ball joints and tie rod ends. I don't have time to go and find it for you though. If that all seems like its pretty tight take one front tire and put it on the rear and see if you have the same problem. if you do swap the other front tire o the back. let us know what you find.
Old Aug 1, 2013 | 08:59 AM
04desire's Avatar
Getting the alignment checked today. Will inform
Old Aug 2, 2013 | 06:28 AM
I will bet that it is not the problem
Old Aug 2, 2013 | 11:27 AM
04desire's Avatar
The shop said the reason is because the subframe is bent. But I dont think thats the reason.
Old Aug 2, 2013 | 08:06 PM
houtex's Avatar
Um... why not? That would definitely cause caster/toe issues if the mounting parts of the LCA were bent.
Did they prove it or just say it? Get it on a rack and ask them to show why.
Old Aug 4, 2013 | 10:20 AM
04desire's Avatar
Would I have to get a whole new subframe or can I get it fixed
Old Aug 4, 2013 | 01:56 PM
depends on how bad it is. Did the guy say it was jacked pretty bad?
Old Aug 5, 2013 | 04:54 AM
04desire's Avatar
It didnt like that bad
Old Aug 7, 2013 | 07:49 PM
AzPete's Avatar
Got pictures of the bent area.....?
Jim74656
May 1, 2023 02:15 AM
Jul 20, 2015 06:26 AM
dohc97
Jul 19, 2015 07:29 PM
Jul 17, 2015 05:40 PM
