More power on the way
Only 8 lbs. of boost. Mods before included BBK shorty headers, BBK 78mm throttle body/plenum, BBK CAI, Comp Cams Stage II cams, Typhoon intake manifold, Magnaflow X-pipe and catback exhaust. The race tune requires racing fuel, so I'm happy with 408. You can't see the top color very well. It's a dark blue with pearl in it, so when you look at it just right it shifts from the blue to purple with a thin stripe of black to separate the blue and silver.
Originally Posted by skunk21
I agree I don't think he is doing it on 8psi but I sure hope it isn't in 12psi either on the stock motor. Gary in my local club is running an intercooled procharger on a dart331 with afrs on his '95. at a Dez racing dyno day it dynoed just over 500 to the wheels at 12psi.
Stout, block yeah internals no. He is running it close. with '03 cobra internals or decent forged stuff those blocks can push 800 no prob. I'd be nervous on the stock stuff.
I dropped down to 10 when I read you were getting an intercooler. What kind of dyno was it? Oh I didn't figure the tune.
We pushed boost on mine but didn't advance the timing that far. As a matter of fact it's first dyno with advanced timing put out 505 so we backed it off.
So kind of the opposite.
PSI and SCFM are what you look for. I'm maxed out on boost not SCFM. Nice 2.9 whipple would give me more power with less PSI. Turbo set up usually allows more airflow which is why gains are a bit higher. Procharger numbers are usually lower than Vortech and Paxton. Procharger's big sales tactic is that intercooler which can be bought separately and used on any kit. Not a big procharger fan.
Originally Posted by Pete07GT
Turbos allow you to use some of the 30% wasted energy you're putting out of the exhaust and turn into useful horsepower. It's easier to blow things up if not mapped correctly (as is the case with ANY forced induction application) but if planned and reviewed then re-reviewed multiple times and built carefully one piece at a time, it will be way more efficient than a supercharger. Wonder of that's why Porsche has used turbos instead of Superchargers?
Well we can battle all day about this. From all of my experience with both, more power had been gained from a turbo setup but they are a lot tougher to tune. So full race car I would consider a turbo but not for street or street/strip. Hard to tune a turbo car for both duties.
60' times I would go supercharged any day of the week. Smoking my tires past Al at a 65mph roll, turboed all day long.
Challenge accepted. Let me know when you're ready. You just better have at least 600hp at those wheels.
And 1000lbs less? Mine weighs in at 3432lbs on the scale, don't think I won't process HP to Weight ratio as a factor. One of the things I learned about from readin' n' such.
Do what you gotta do Pete. 4th and 5th gear are scary fast in the cobra. So far the only car that has given me any kind of run was a 12' GT500 punching off at 80. And he still got beat.
And what kind of lap times are you laying down there Al? I didn't invest in mine to go in straight lines.
Originally Posted by sampey43
Just make sure you challenge on a track and not on the street as tms does not promote the butt whippin you will get on public hwys pete
All in good fun though.
Just hurry up and build it already. Drag, roll race, road course. Hell I dont care. The best chance you have is 1/4 mile.
