More power
Indeed, how far are you planning to go with your crate motor?
If its a non PI motor, PI heads are a great swap, better heads plus a bump in compression.
It's a non pi head motor bone stock v8 engine pushing out about 245 hp I wanna just little mods until I get out tech school. By the end I want a nice 325 hp before a supercharger is out in
I had the PI motor in my 02 and i added a 75mm throttle body, k&n CAI, borla stinger catbacks, mac prochamber midpipe, and 3.73 gears. Dynoed it once before and after i installed a bama tune. Sadly i dont have the file for it because it was saved on my flash drive that i got caught in the rain with. I believe it was right around 310-315 though
Needs to be more Astony
PI swap on a 98 actually gives more like 270-275 do to slightly higher compression that that happens on the 96-98. So with all the boltons he could possibly reach his 325hp goal. Through in a cam or long tubes to the above list and he should be good.
Rando
8/25/21 11:12 AM
