Missfire??
Old Aug 16, 2013 | 02:13 PM
Fastang97's Avatar
Missfire??
I have cylinder #6 misfire... Will changing the spark plugs and wire do the trick??
Old Aug 17, 2013 | 03:17 AM
shaunrc's Avatar
If it is the spark plug yes but it could also be a clogged fuel injector as well or a bad wire. If you take the spark plug out and hold out of the spark plug hole and start it you can see if it sparks. If it does you know its not the plug or wire the only thing after that would be the injector
Old Aug 18, 2013 | 04:48 AM
h82looze's Avatar
Number 6 Misfire
Also when checking your spark plug, if it's bone dry when u pull it your not getting fuel and if it's soaking wet your probably not getting spark or enough spark.. Also before pulling the plug makes sure you have good connections on plug/coil pack.. Lastly check your spark plug gap..
Just remember Fire, Fuel, Fresh Air is what you need for combustion..
When I had my misfire it was from coolant leaking into the cylinder's spark plug hole flooding out my plug, essentially grounding it out.. (4.6L)
Best of luck to you
Old Aug 18, 2013 | 10:15 AM
shaunrc's Avatar
Best of luck to you
If your spark plug is dry when you pull them does not mean you are not getting fuel. If you have complete combustion your spark plug will be dry cause all the fuel is igniting.
Old Aug 22, 2013 | 02:41 PM
escottcarp's Avatar
You might have a bad coil. Do you have a trouble code?
ZRX4ME
Nov 27, 2013 06:00 PM
jc46002003
Nov 22, 2013 11:29 PM
tacosrock143
Nov 20, 2013 06:10 PM
bootstrap_bill15
Aug 15, 2013 11:46 PM
carman
2012-2013 BOSS 302
Aug 18, 2012 09:09 PM
