Long Tube Headers
Old Apr 18, 2013 | 04:17 PM
GONGRN's Avatar
Long Tube Headers
Who makes the best long tube headers for a supercharged application? I am being told that I could pick up 20-30 hp over the stock exhaust manifolds.
Old Apr 18, 2013 | 05:11 PM
bluethunderhorse's Avatar
Stainless Works, but they'll cost you $1,200-1,600
Old Apr 18, 2013 | 05:20 PM
GONGRN's Avatar
Holy Craps!! A little outside the budget!!
Old Apr 18, 2013 | 05:54 PM
everything I looked at for my 2k gt was not worth the cash for the hp gain I would get out of spending the cash...... of course mine wasn't supercharged
You can get Mac or bbk for around $500
Old Apr 18, 2013 | 05:57 PM
Food for thought though Kenne Bell did a dyno test on a 800 HP Shelby and gained 12 HP with long tubes 3" catted x pipe and axle back
Old Apr 18, 2013 | 06:03 PM
1999Pony's Avatar
Old Apr 18, 2013 | 06:23 PM
KARL’S EAST COAST SPEED
827HP Shelby. Headers, 3” x pipe and no cats. 2HP!
“Hi Flo” cats? Really? Show us your flow tests. HP tests. Our 1000HP air flow bench reads 407 cfm stock and 549 cfm gutted and no HP gain at 775RWHP. Besides turning on your engine light, gutting or removing cats has another drawback - the exhaust gets raspy (noisy).
Still want to gut those cats - or buy some “Hi Flo’s?” We welcome any magazine to come to Kenne Bell and test back to back on any Mustang - ours or theirs. We’ll hook up the data logger and record back pressure, air flow, temperature, etc. and, of course, HP with and without cats. All at no cost - IF it’s printed in a magazine. And we promise the tests won’t be skewed by changing ignition timing, AF ratio, pulley (boost), x pipe, headers, exhaust etc. to increase HP. You know how that can go. “Cats and a tune,” Cats and a pulley,” “Cats and cat back . . . “ Just a typical Kenne Bell back to back cat test.
My Bad I was all wrong. Been a while since I read it
HEADER, CAT, X PIPE & EXHAUST TESTS
‘05 MUSTANG, ‘07 SHELBY
There’s a sign on our dyno given to us by an old Ford engineer that reads “One of the real dangers in running a test is you’re bound to get data.” At Kenne Bell, we test ONE product or change at a time. We NEVER install a product and use a different AF ratio, timing, or use another product as a “crutch” to enhance it’s performance. That is misleading. Over the years we’ve received complaints about our kits not making the HP with headers, etc. Our customers often add the ADVERTISED HP claims to their HP expectations and then blame the supercharger when it doesn’t all add up. So we decided to do a “one product at a time” Kenne Bell style - exhaust, x pipe, cats and header test on our own ‘05 Mustang test car - the one used for our literature, dyno tests, etc. It was equipped with only the new MAMMOTH™ 2.8H Kit. We were shooting for 800RWHP. It made 279RWHP stock and 750 with only the MAMMOTH™ Kit on a 100% stock spec Sean Hyland built motor (no cams, heads, higher comp, etc. Just an electric water pump. The Sean Hyland motor made exactly 279HP, the same as our stock motor. Here are the tests.
RWHP TEST
279 - Stock baseline
750 - MAMMOTH™ 2.9H Kit
775 - Bassani cat back
775 - Remove exhaust
775 - Custom x pipe
775 - Remove x pipe
775 - Remove cats
775 - Install 1-3/4” headers
775 - Install cats
775 - Install gutted cat pipes w/headers
775 - Install stock x pipe
775 - Install custom x pipe
750 - Reinstall stock exhaust
Plenty of 775’s because we saw no gain from the headers, x pipe or cats. Get the message? Like it or not, these are the Dynojet results. Same dyno, car, timing and AF ratio. And the headers, no cats and x pipe did not lower boost. These results are in line with other one change at a time - back to back tests that Kenne Bell and some of our Tuners have run on the ‘03 Cobra and ‘07
Shelby. Then there’s the well documented “Mod for 4V Fords, Part ll - and Part lll” Muscle Mustangs & Fast Fords Magazine ‘03
Cobra engine dyno tests. This Kenne Bell supercharged Sean Hyland ‘03 engine ultimately made 940HP. With Bassani exhaust and lower boost it pulled 677HP. Long tube headers increased power to 682 (+5HP). Note that the 5HP was made with OPEN 3” collectors and NO cat back exhaust. So was the mere 5HP in the headers or the 3” open collectors? Still believe headers are 50HP? See what happens when one makes TWO changes at once? Uh oh! Opinions! Later the 1-5/8”x3” headers were swapped for a set of 2-1/8” and the ‘03 Cobra made another 50HP! Yes, the “right” headers make HP. Sometimes nothing or very little but it is what it is. We would have very much liked to make some HP with the headers and push our MAMMOTH™ powered ‘05 kit over 800HP with only headers and a cat back. One would think that if stock manifolds were such a huge restriction why no HP gain at a whopping 775HP.
Here’s more food for thought. The stock cat flowed 407cfm (814 for 2). Gutted cats were 549 cfm (1099 for 2). Think “Hi Flo” cats at ? cfm would have made more HP? We’ll let you guess at the flow of the x pipe and exhaust. In 2004, back to back tests on Earl’s 700HP Cobra also resulted in a “0” HP gain when he gutted the cats. He was told by experts to expect 35HP. Same results
桥慤敲彣慴彸灩灥彥硨慵獴彴敳瑳 坥摮敳摡礬⁓数瑥浢敲′㐬′〰㠠㌺㐰㨵㔠偍
for ST Motorsports on their 700HP 3V ‘06 Mustang test i.e. no HP gains from gutting the cats. ST changed the headers AND exhaust and made 25HP! Oops! Again, TWO changes at a time. Header leaks, tuning issues and HP claims simply consume too much of our tech people’s time. Kenne Bell is not against any product that nets power gains. We would recommend that header companies do more accurate back to back header ONLY tests and not leave the claims and testing to “others.”
The three 775HP runs are very close together. Too close to call.
1. 100% stock headers, cats, x pipe w/ no exhaust.
2. Stock Manifolds. No cats. Open exhaust. No x pipe.
3. Headers. No cats. Open exhaust. No x pipe.
Here’s another back to back test on an ‘07 Shelby GT 500. Earls East Coast Speed
Kenne Bell Supercharged ‘07 Shelby
STOCK MANIFOLDS, STOCK CATS, STOCK X PIPE, CAT BACK
762RWHP / 677 RWTQ - 19.25 psi boost
ADD 1-3/4” HEADERS, 3” X PIPE, REMOVE CATS
764RWHP / 683 RWTQ - 18.75 psi boost
2HP! 14 FT LBS! What would your guess have been?
Headers ? X pipe ? No cats ?
HP ?
Kenne Bell doesn’t sell headers, nor do we gut cats. All we can do is run the tests and pass on the information to our customers. The decisions are yours.
Old Apr 18, 2013 | 07:44 PM
1999Pony's Avatar
Its amazing how good Fords stock manifolds really are. Surprises me everytime.
kponypower
Jun 17, 2020 07:17 AM
wallace
Mar 29, 2016 10:09 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Sep 30, 2015 07:02 PM
