Long crank time
Old Sep 13, 2011 | 09:29 PM
br23will's Avatar
Long crank time
My mustang will crank a little long sometimes. Some will turn right over then almost die. Once it's running it's ok. Also it just doesn't always have as quick acceleration as it should, no misfire or CEL. Any thoughts on what it might be?
Old Sep 13, 2011 | 09:58 PM
StangSims39's Avatar
the battery might be going, have the batter checked out at autozone, you may need to replace it, a fresh battery will start the engine in a second
Old Sep 14, 2011 | 07:17 AM
Onesickstang01's Avatar
Have you changed the fuel filter? I would start there
Old Sep 14, 2011 | 07:29 AM
br23will's Avatar
I have changed the fuel filter. Battery tested fine
Old Sep 14, 2011 | 07:45 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Fuel pump.
Old Sep 14, 2011 | 04:17 PM
Yea probably fuel pump. Only other one if seen similar was an injector stuck open and letting fuel through. Drops fuel pressure and floods a cylinder
Old Sep 14, 2011 | 09:27 PM
br23will's Avatar
I've got good fuel pressure. The starting issue happens at random. Not after sitting. Is there anyone that has had this happen to them? Maybe you've found a solution. I don't have enough money to guess
Old Sep 14, 2011 | 09:34 PM
Bear Eats King...
Bear ****s Bone
Hose in the tank connected to the fuel pump. It has a small hole in it that leaks the pressure out while it sits.
Try this. Before you start it cycle the key on and off 3 times for 10 seconds apiece.
Bet it start easy after you do that.
Old Sep 14, 2011 | 09:44 PM
ucdavis4.0gpa's Avatar
Yeah that's backwards from the hot seize fuel pump failure....you could also check fuel pressure when the car has sat overnight if you haven't already...if its good that would rule out a system leak. It's weird though cause this reeks of a fuel delivery problem...its is possible the pump is intermittently failing which has been known to happen.
Old Sep 14, 2011 | 09:47 PM
Bear Eats King...
Bear ****s Bone
It could be but he said once its going it doesn't die. I'm almoast certain its a hose leak in the tank. Seen it so many times.
tukatz
Oct 13, 2023 10:01 AM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
GT/CS Guy
Aug 13, 2015 07:54 PM
