Induction Size
Old Jun 26, 2008 | 09:34 PM
Cobra Drifter's Avatar
Induction Size
Is bigger always better when it comes to induction? I am looking at upgrading my throttle body to a 70 mm or 80mm but what about the Mass Air meter? I found a recommended 90mm one but shouldnt both parts match diameters?
Old Jun 27, 2008 | 04:54 AM
Evil_Capri's Avatar
If this is for your Cobra you need to post in the appropriate section. I will move but will also leave a link for a day.
Old Jun 27, 2008 | 11:16 AM
Well I wasnt sure where to post as there isnt a section for induction or performance like other forums. Its a general question about induction size really but yes its for my Cobra.
Hmm, well this isnt where I would think it goes but from no responses in this forum guess it would have been best left in General (although this site is very low in traffic )
Old Jun 27, 2008 | 07:55 PM
CircuitBreaker's Avatar
Bigger isn't always best. Its time to upgrade parts when they become the restriction in the chain of airflow. Intake air may lose some of its velocity going in due to the bigger opening.
In the case of my Gt thats still NA, the stock 65mm TB flows enough air. A 70 or 75mm would only be worth a couple hp at best.
Old Jun 28, 2008 | 01:15 AM
Thanks for the reply.
So basically its a waste of money unless you can utilize the extra airflow. But how do you know when to increase it and by how much?
Old Jun 28, 2008 | 04:19 AM
Evil_Capri's Avatar
You need to lay out your goals for your Cobra to identify not only the proper parts to achieve your goals but factor in a time table of when to purchase the parts at the proper time.
You can obtain all sorts of good information for your New Edge snake on svtperformance.com.
Old Jun 28, 2008 | 02:42 PM
Yup, I joined both sites same day and yes they do have a great site too. Getting good replies there and all.
I probably wont put a supercharger on it but bigger injectors, TB, plenum, CAI (already have) and full exhaust system (Basanni). This is about as much as can be done to increase hp without a SC I guess other then the required dyno/tune. So with that I dont know what sizes I should get.
Old Jun 28, 2008 | 11:11 PM
This would be a good book to get to learn from:
http://www.jegs.com/p/S+A+Designs/760401/10002/-1
Lots of testing with dynosheets.
Old Jun 29, 2008 | 03:07 AM
Thanks CircuitBreaker
Old Jun 29, 2008 | 04:21 AM
Evil_Capri's Avatar
I don't think you will need injectors with the other items you have listed. You also forgot to include an intake spacer. I would say 1/4" to 3/8" would work well.
What tuner application will you be purchasing (if you don't already have one?) Have you selected a shop to perform the tune on the dyno? They also may have some insight.
If you don't want to go the SC route, you can also have your intake ported, add new heads/cams, etc. But these are expensive . . . but could also improve your engines performance N/A or SC.
Old Jul 6, 2008 | 01:33 PM
conv_stang's Avatar
does the Mach 1 have the dual bore TB like the cobras? single blade TB from accufab would be a good upgrade
Old Jul 7, 2008 | 05:12 PM
boduke0220's Avatar
yea theres alot more such as heads ...cams... headers ..gears
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
Feffman
Sep 28, 2015 06:46 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Feffman
Southeast
Sep 24, 2015 05:06 AM
