Idle problem
Old Dec 3, 2012 | 05:03 PM
alfredoGt's Avatar
Idle problem
Some part of my intake manifold broke and and a hose went out on me too.i purchased another one and installed it along with some new sparkplugs.we pluged everything in and before i out the throttle body and plenum i decided to clean it a bit.when i started the car it felt accelarated and the exhaust is loud.when im coming to a stop and when i press on the clutch ready to go my rpms go a lil past 2krpms.Any idea what it could be please help.thanks
Old Dec 4, 2012 | 03:24 AM
Jet Life's Avatar
Sounds like a vacuum leak somewhere. You may have popped a hose off somewhere. Grab a can of carb cleaner and spray a light mist around the engine and listen for the motor to rev up. Then try to pin point where the vacuum leak is. Also did you fix your cracked intake manifold?
Old Dec 4, 2012 | 05:30 PM
alfredoGt's Avatar
Ok ill try doing that..yes purchased a new one and installed it
Old Jan 22, 2013 | 06:28 PM
Nrgahan-94GT's Avatar
You may need to reset you iac. Look it up on google for the exact steps, but basically you have to go through a couple sets to let your computer re-learn where to idle. Usually a big problem with 94-95 5.0's but it is worth a shot. It's free, easy and only takes like 45 mins so it can't hurt.
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Airborne42
Sep 24, 2015 11:01 AM
